Author Topic: 3.2 elite auto false neutral  (Read 1177 times)
PAULCBX666666
  • Milton Keynes
« on: 13 September 2011, 20:08:12 »
Hi, have a 3.2 Elite that will occasionally at slow speed pullaways find a false neutral and lose drive, have found I can pop it into 3rd gear and accelerate normally then pop it back into drive and all back to normal!! any ideas on what this could be? Not a high milegae car or anything (only 87k or thereabouts)
Thanks Paul
Re: 3.2 elite auto false neutral
« Reply #1 on: 13 September 2011, 20:10:16 »
Check level and condition of ATF first mate  :y
PAULCBX666666
  • Milton Keynes
« Reply #2 on: 13 September 2011, 20:15:54 »
okay sounds like a good place to start, doesn't miss a beat at higher speeds or under heavy load which is where I thought low levels would affect it more?
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #3 on: 13 September 2011, 20:32:12 »
this kind of problem has been frequently posted up. I would go for crank sensor and change of ATF.
I  had exact same problem 2 years ago. Trouble is it could be other things such as solenoids in gearbox.
PAULCBX666666
  • Milton Keynes
« Reply #4 on: 13 September 2011, 20:36:23 »
I'll try fluid then sensor if no joy and see how I get on Thanks for that
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #5 on: 13 September 2011, 21:56:23 »
i had the same symptons when the torque convertor gave up in my auto box on holiday.
hope yours wont do the same  :-/
2woody
  • Northumberland
« Reply #6 on: 15 September 2011, 08:47:52 »
is there a "how do I check the fluid ?" in the making here ?
« Reply #7 on: 15 September 2011, 09:11:45 »
Already been done!  ;) http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
Page created in 0.026 seconds with 16 queries.
