Author Topic: diesel injector pump  (Read 1156 times)
shadwell1981
  • leeds, west yorkshire
  • welsh man in town!!
« on: 12 September 2011, 21:42:27 »
hi
i have just bought an injector pump for my 2.5 td. the one fitted is on its way out ( loud noise when running). the question i have is, how do i go about fitting it. i know my way aroud and engine and compitent to change it. is there any tip you could give or should a diesel expert change it?
i have not been let down by you all, as every question i have posted has always resulted with the correct answer and no bull!
changing this part should hopefuly raise my mpg and mybe power?
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: diesel injector pump
« Reply #1 on: 13 September 2011, 00:43:53 »
Take a look here - just click:  http://www.omegaowners.com/forum/YaBB.pl?num=1290534473
HTH ;)
shadwell1981
« Reply #2 on: 13 September 2011, 11:28:52 »
thank you for the link.
as i said, you have never let me down!! :) :)
hoofing it
« Reply #3 on: 13 September 2011, 11:56:57 »
Ive got a set of inlet gaskets here if you need them(somewhere) :y
shadwell1981
« Reply #4 on: 16 September 2011, 21:23:41 »
i have just picked up some gaskets from the local factor, and they look like 6 elastic bands. are they right? i thought i should have something flat with one large hole and two holes for the studs to go through.
Omegatoy
  • UK
« Reply #5 on: 16 September 2011, 21:32:09 »
yep six seperate gaskets for the inlet :y
