Author Topic: Whining Noise - tyres or something else ?  (Read 4433 times)
Rog
« on: 14 September 2011, 16:25:12 »
Picked up my "new" '52 CDX V6 Estate today. before buying I noticed strange tyres "Sunny" brand, never heard of 'em.
Driving home I was aware of a whining noise, high pitched at speed, lower when slow. No obvious vibration.
Do you think this is car (axle, wheel bearings or something)  or tyres ? Mileage verified with HPI at 53k.
I_want_an_Omega
Re: Whining Noise - tyres or something else ?
« Reply #1 on: 14 September 2011, 16:30:24 »
could it have been coming through the stereo? This can happen even with the volume down to zero
« Reply #2 on: 14 September 2011, 16:44:04 »
differential ?
« Reply #3 on: 14 September 2011, 16:49:05 »
There more than likely responsible
« Reply #4 on: 14 September 2011, 16:54:15 »
I thought that at first , but high pitched whine ? :-/
Depends how high pitched, and how whiney. :-/ :D
Rog
« Reply #5 on: 14 September 2011, 17:02:29 »
High pitched at speed, low pitched when slow, actually goes up and down according to speed.
However, since posting I found this link below !
http://www.tyrereviews.co.uk/Tyre/Sunny/SN3800.htm
Hmmm, looks like a complete set of decent new tyres needed soon  ££££   :(
« Reply #6 on: 14 September 2011, 17:04:56 »
check their dates, if fairly new, you can use for some time..
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #7 on: 14 September 2011, 21:59:48 »
first time hearing of a tyre brand which is terrible in all aspects, and not a single good review about it..
I guess thats what happens when there aint any actual tests that need to be passed in order to produce a tyre  >:( >:(
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #8 on: 14 September 2011, 22:39:57 »
are the tyre pressures right. could also be the tyres not worn in yet.
Solar charger fitted.
If not Broke dont fix it..
« Reply #9 on: 15 September 2011, 13:21:42 »
May find the noise goes with use.
But regardless, bin the sunnys.
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #10 on: 15 September 2011, 13:39:04 »
As cem sadi possibly rear differential. Have a quick look underneath the car to see if it is leaking - if it is then you could top up the fluid level to start with (£10ish) or may need to replace the pinnion seal (£20ish)
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #11 on: 15 September 2011, 17:06:04 »
does the noise get worse when cornering at speed..?
Rog
« Reply #12 on: 15 September 2011, 17:56:13 »
Took it for a run up to the Midlands, 200 mile round trip.
Worse between 30-60mph, almost disappears at 75 and above.
I've almost convinced myself it's the tyres, I hope so as although a new set will cost, its an easy fix.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #13 on: 15 September 2011, 18:42:02 »
I had a similar problem and new tyres sorted it
Rog
« Reply #14 on: 16 September 2011, 09:01:42 »
So, new tyres all round it is then.
Any suggestions what ?
My priorities are:
Safe at speed (I drive abroad quite a lot, occasional thrash on an autobahn)
Reliable
Quiet
Not bothered about fancy performance type features. I'm bracing myself for around £400 for the lot.
« Last Edit: 16 September 2011, 09:22:29 by Rog »
