Author Topic: Brake Service Advice  (Read 3277 times)
Re: Brake Service Advice
« Reply #15 on: 15 September 2011, 23:37:10 »
....  on TC it was just shy of £122 ....
Ouch!  :(
Yup  .. but should have been £134 + VAT !!!!!  :(
not that much consolation  :( :(
« Reply #16 on: 16 September 2011, 01:26:57 »
When I rebuilt my front calipers I was advised to use Red Rubber Grease inside the slider pin gaiters.
You may find that they yours are dry and not releasing the pad.
I was just about to say - shouldn't it be Red Rubber Grease anywhere there are rubber boots (usually on the sliders - not looked at the Omega yet, mind).. definitely not copper grease and not really generic grease either (both of which could cause the rubber boots to swell and bind or split).. JMHO :)
« Reply #17 on: 16 September 2011, 09:43:14 »
and not really generic grease either  .....
but for most people that don't have access to a range of greases a universal grease would be better that nowt.  ;) ;) ;)
« Reply #18 on: 16 September 2011, 12:23:37 »
Very true.. but then it's not that hard to pop to the local motor factors and get a tin of the right stuff ;)
Well.. unless you live on the Isle of Skye or something like that  ;D
« Reply #19 on: 16 September 2011, 12:27:22 »
Very true.. but then it's not that hard to pop to the local motor factors and get a tin of the right stuff ;)  ...........
Do you mean that some people actually BUY grease ................... ? :-?  :-?  ;D ;D ;D
« Reply #20 on: 16 September 2011, 12:33:07 »
I hear it can be bought.. I always thought it just fell off a shelf somewhere and came home with me.  ;D
Wait, I lie, I did once buy a tub of general purpose grease.. about 10 years ago  ;D
« Reply #21 on: 16 September 2011, 12:35:18 »
I hear it can be bought.. I always thought it just fell off a shelf somewhere and came home with me.  ;D ....
Did it fall, or was it pushed?  ::)  ::)  ;D ;D ;D
My garage is full of stuff that was pushed .....  :-X :-X
« Reply #22 on: 16 September 2011, 12:37:04 »
Earthquakes. I blame earthquakes ;)
I may have to resort to buying it, though, since I have no access to shelves anymore :( and if I build this kit car I'll need it - it'll be covered in re-packable bearings and grease nipples :) (better get a grease gun, too!)
« Reply #23 on: 16 September 2011, 13:15:49 »
I have to buy my own grease  :'(  and seem to use more of it on other peoples cars than my own!
« Reply #24 on: 16 September 2011, 13:20:20 »
I bought a tub of grease in 1982 when rebuilding chevette HS engine. Its still about quarter full. I obviously use it sparingly. ;D
Get through quite a bit of copper grease though. ::)
« Reply #25 on: 16 September 2011, 14:00:22 »
let me know before we both go to the same meet.  ::) ::)  :y
« Reply #26 on: 19 September 2011, 10:58:09 »
Bottom bolt on Drivers side calliper was seized solid.
Eventually freed it off, greased up, and bled.
What a difference!
