Author Topic: Cam Timing  (Read 2751 times)
Cam Timing
« on: 18 September 2011, 22:05:18 »
As some may have read the Pink One came down last week to change my cambelt etc for me ..
http://www.omegaowners.com/forum/YaBB.pl?num=1316121161
It was at 38700 miles and 3 years 8 months since changed as parrt of the deal when I bought the car. Never been touched since then. All the old bits were genuine GM parts, and it looked like the water pump had been done as well .. so a half-decent job I thought ...  until Daz pointed out that the passenger bank was 1/4 tooth out and the drivers bank about 1 1/4 teeth out ... When he did the job he took great care to ensure both sides were spot on ......
Now in the nearly 4 years I've never had cause to call the beast "underpowered" .. it went well and pulled the 'van without effort .. an fuel consumption was, I thought, quite reasonable for 3.2 litres in a 1.7 tonne vehicle driven quite sportily at times.
I've been away at a reunion this weekend .. done around 400 miles since he did the job and the difference is really noticeable .... engine is more responsive and quicker off the mark and fuel consumption is better by about 6% !!!
So, not only do you need to know what you are doing, the proper timing tools are essential to get the best performance from the engine. Makes those who say you can time the V6 without the tools even more wrong IMHO ... I did not expect it to make as big a difference .
Once again ... thanks DAZ   :y :y :y :y
Re: Cam Timing
« Reply #1 on: 18 September 2011, 22:42:16 »
... Makes those who say you can time the V6 without the tools even more wrong IMHO ...  ....
It's always been said that it was at best, a good guess.  :y :y :y But apparently the tensioner also make a difference to the timing ..............  ::) ::)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Cam Timing
« Reply #2 on: 19 September 2011, 09:17:57 »
Sounds like a Good Result there Nige  :y
I know when Mrs. loo-knee's estate timing was out we got 27mpg on a run. After I had put it right it did 35mpg on the way down to Devon packed up for holidays :y
It is suprising because I did a Cambelt the other day which was a new engine from Vauxhall, again never been touched since it came from the factory and yet again the timing was out........
Andy as far as I see the tensioner just keeps the belt tight.  :y
Re: Cam Timing
« Reply #3 on: 19 September 2011, 09:36:57 »
You & I know that, but a certain admin & I had a long winded 'debate' about the subject  ::) ::) ::)
Re: Cam Timing
« Reply #4 on: 19 September 2011, 10:14:18 »
I really must check mine - I get ~26-27 on a run in the 3.2, and as I found out this morning, struggled to out-drag a Toyota Carina (Corona?)  :-?
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Cam Timing
« Reply #5 on: 19 September 2011, 10:23:06 »
Just done a 600 mile trip and at 70mph ish i was getting 32mpg from the 3.2 Elite is this about right. :-/
Re: Cam Timing
« Reply #6 on: 19 September 2011, 10:30:52 »
What I have stated is that you cant set the tension correctly when the cam timing is out (as the cam lobe positions affect the belt tension on the sloppy side)
At no point have I stated that the tensioner affects cam timing.
Re: Cam Timing
« Reply #7 on: 19 September 2011, 10:35:43 »
Well it's better than I get  ;)
Re: Cam Timing
« Reply #8 on: 19 September 2011, 11:22:09 »
I was refering to A N Other boyish admin  :y :y :y  ;D ;D ;D
Re: Cam Timing
« Reply #9 on: 19 September 2011, 11:59:41 »
As MDTM says, you can't set the tension correctly if the cam timing is incorrectly adjusted. Thats why its the last step in the renewal procedure.
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Cam Timing
« Reply #10 on: 19 September 2011, 12:08:00 »
I think that sounds a good MPG return mate :y  3.2's seem to be more thirsty in my opinion than the 3.0   :)
« Last Edit: 19 September 2011, 12:08:56 by Loo-knee »
Re: Cam Timing
« Reply #11 on: 19 September 2011, 12:14:20 »
My belt was changed by VX so I'm well and truly Donald Ducked. :-/
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Cam Timing
« Reply #12 on: 19 September 2011, 12:25:39 »
Where I think Vauxhall's problem is, (again in my opinion just so I don't get stoned to death ;D) they put the belt on using the locking kit, get the timimg right then torque everything, then put it back together.
Anyone who has done any Cambelts should know that when you have put on the belt, making sure the timing is spot on so tighten everything, then turn the car over by hand that the timing is slightly out when checked again. So should then be fine tuned. This is where Vauxhall go wrong...... In my opinion as they do not turn the engine over by hand a few turns, then re check, turn over a few times then check  ;)
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Cam Timing
« Reply #13 on: 19 September 2011, 12:28:56 »
9 out of 10 people who say their car cambelt has been done by Vauxhall, I would feel safe enough to put money on it being out.
It sounds stupid I know but true  :-?
Re: Cam Timing
« Reply #14 on: 19 September 2011, 12:58:50 »
A little nibble there I think ......  ::)
