Author Topic: My tractor is getting lazy at firing help needed  (Read 9140 times)
Shark1e
  • Stoke on Trent
    • Meega 2.5TD-CD Estate
Re: My tractor is getting lazy at firing help needed
« Reply #30 on: 15 September 2011, 15:46:55 »
as you suspected the sender is not the same as the one on my pump, thanks to greenhouse vauxhall clough street hanley, your crap !!!!!
anyone got a diagram of the pump so i can try and workout what the sender type item is on the top of my pump,
spoke to swadlincote diesels near burton on trnet today, done work on a vectra some years back for me,
he has confirmed that the issue is the pump going faulty.
but as always pop it in for a bosch hookup and all for a cost of £42 + vodka and tonic.
then depends what we find as we may need to discuss with you further tests. lol
can anyone tell me if this fuel temp sensor is behind the square black box / cap on the side of the pump?
something else which maybe nothing or something, injector 1 nearest rad has oil in the bottom gathering, fairly sure i cleaned this up sometime ago, can't see oil running anywhere to drip into the injector well etc.
deff oil as i licked it lol.
also noticed on the injection pump two of the injector pipes looked dirty / damp / wet so cleaned all off with carb cleaner, i will check over the weekend if it has returned.
2.5 cdtd omega 1999 manual estate Chipped and poorly at the moment -  is there a doctor in the house
hoofing it
« Reply #31 on: 15 September 2011, 16:05:49 »
Heres the link.
The only thing I'll say is the fuel temp sensor is a factory fix (Bosch).Trust me been there done that
The plactic bit that holds the throttle control is also the temp sensor:y
http://www.omegaowners.com/forum/YaBB.pl?num=1284826092
« Last Edit: 15 September 2011, 16:08:54 by hoof »
Shark1e
  • Stoke on Trent
« Reply #32 on: 15 September 2011, 16:09:55 »
on picky one! the sender type item is to the right of the green arrow, what is this part?
hoofing it
« Reply #33 on: 15 September 2011, 21:00:24 »
Thats the fuel pump solinoid it's only to start/stop the engine.
There is a sensor at the base of the pump (black wire) this is the fuel qauntity this throws up code 34 and again this is a factory/diesel specialists fix :y
Shark1e
  • Stoke on Trent
« Reply #34 on: 15 September 2011, 21:07:08 »
Think i will plug my "My Naff Code Reader" in and live data it when cold and repeat it when hot. it may show something up.
hoofing it
« Reply #35 on: 15 September 2011, 21:12:07 »
Just do the paperclip test and see what codes are there :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #36 on: 16 September 2011, 01:09:06 »
Here's the codes: http://www.omegaowners.com/forum/YaBB.pl?num=1205270870
Shark1e
  • Stoke on Trent
« Reply #37 on: 16 September 2011, 17:09:46 »
done the paperclip test and got two codes 12 & 96
my "My Naff Code Reader" keeps picking the 96 but not checked lately so 12 may be new but can't find what code 12 is?
Shark1e
  • Stoke on Trent
« Reply #38 on: 16 September 2011, 17:15:50 »
DOH!!!! lol i really should read more lol
code 12 is start of test lol so all i have is 96 egr out of range what ever that means,
it had a brand new egr valve on the old gal just before i brought it. this code came up on the "My Naff Code Reader" so i stripped and cleaned the egr valve the re fitted, so no idea on that one.
hoofing it
« Reply #39 on: 16 September 2011, 19:07:02 »
Take the vac hoses off and give them a clean with some carb cleaner also look for cracked pipes. :y
Omegatoy
  • UK
« Reply #40 on: 16 September 2011, 19:20:27 »
egr can get sticky as well even a new one,give it a clean up,  :y
Shark1e
  • Stoke on Trent
« Reply #41 on: 16 September 2011, 20:03:29 »
i had this issue in another post not long back, and if i'm right this is when this lazy starting began or is that just a coincidence,
i had three pipes on the wrong valve ports etc. hope i have them right now urrrrmmm
another thing i have been trying to code a s/h key from fleabay and had my lappy plugged in via "My Naff Code Reader", wasn't long before i needed to get a jump start off the mrs KA jeeez the embarssment or what. wonder if it is the battery not juiced enough????
OMG its a conspiracy making me go mad now, my meega is haunted i'm sure.
Shark1e
  • Stoke on Trent
« Reply #42 on: 16 September 2011, 20:05:51 »
was all stripped off and cleaned with carb cleaner only 2 months ago when i pulled off the code 96 on my "My Naff Code Reader", strange it is not showing up on "My Naff Code Reader" anymore. mind you i chose clear faults so wonder if i paperclip it again now will it not show up?
Shark1e
  • Stoke on Trent
« Reply #43 on: 17 September 2011, 19:02:07 »
anyone confirm this part please as i changed it not long back for one off a vectra as my clips had broken,
again around when i started getting this problem starting.
maybe nothing as i though this was for the alarm lol
« Last Edit: 17 September 2011, 19:03:26 by shark1e »
« Reply #44 on: 17 September 2011, 19:12:42 »
yes, bonnet switch for alarm  :y
Pages: 1 2 [3] 4  All   Go Up
