Author Topic: Orange Car & Spanner Light.  (Read 1573 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« on: 20 September 2011, 04:52:10 »
Morning!
Yesterday afternoon when starting the car she started really rough and lumpy but settled after a few seconds but the service (is that what it is?) has light came on.   :-/
Hasn't affected performance or anything, just wondered if the lumpy idle on starting has bought the light on for some reason?  Is it going to be a Tech2 job to find out why its come on?
Cheers  :y
« Last Edit: 20 September 2011, 04:52:51 by P6UL_K »
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Orange Car & Spanner Light.
« Reply #1 on: 20 September 2011, 06:05:05 »
Spanner light is the engine managment light. Engine-shaped is for emissions control faults.
Read the codes, pedal trick is explained in maintenance guides, as well as are all the fault codes. I suspect you have 0300 and some other 030-codes for misfire due lumpy start. Maybe also 0335 for crank sensor, which might be the origin of poor starting.
P6UL K
  • Dartford, Kent
« Reply #2 on: 22 September 2011, 18:26:32 »
Ok, just been out and done the pedal trick and here's the results...
1 Very brief flash just as all the other lights go out then...
5-2-3
Then nothing, no more flashing - stays off.
Any ideas?
*Edit*
Could this be it?
P1523 Electronic Throttle Control Malfunction
« Last Edit: 22 September 2011, 18:29:33 by P6UL_K »
« Reply #3 on: 22 September 2011, 18:36:24 »
reckon so ;)
P6UL K
  • Dartford, Kent
« Reply #4 on: 22 September 2011, 18:37:37 »
Ah rubbish!  :(
So what does that mean, its knackered and needs replacing?
« Reply #5 on: 22 September 2011, 18:40:53 »
Assuming no symptoms, clear it out, see what comes back...
P6UL K
  • Dartford, Kent
« Reply #6 on: 22 September 2011, 18:46:55 »
Nah nothing, car seems to run just dandy!
Is there a guide on how to clear the codes also?  :-[
« Reply #7 on: 22 September 2011, 19:03:58 »
Guide for clearing codes...........................code reader ;D ;D :y
P6UL K
  • Dartford, Kent
« Reply #8 on: 22 September 2011, 19:06:22 »
I figured that might be the answer lol...
No one in Kent tho, a right PITA!  :D
« Reply #9 on: 22 September 2011, 19:07:42 »
Pick `em up cheap enough........................or you could drive to Bristol :D
Page created in 0.028 seconds with 16 queries.
