Author Topic: stereo problems  (Read 11039 times)
zywiec
  • Cambridge
stereo problems
« on: 14 January 2007, 13:53:39 »
hi i have a face lift 2000 omega which has the CCR 2006 stereo which doesn't want to play the cd changer, the cassette and radio are fine but when ever the i turn on the cd player it display 'CDC CODE' which obviously means it wants the code put in i have 3 different codes off which my brother has imputed them with no sucsess he has also tried to turn it off (disconnencting the battery) to reset the stereo, he enteres the code and every thing else works but still not the cd player does this have a separate code or need inputing it in a different way?? or do i need to go to the stealers to reset it??
i havn't tried inputing any codes myself.
Paul M
  • Edinburgh
Re: stereo problems
« Reply #1 on: 14 January 2007, 14:01:23 »
There's a different procedure for entering the changer code, I don't know if off hand but someone will be along shortly  8-)
philayl
  • Wirral, Merseyide
Re: stereo problems
« Reply #2 on: 14 January 2007, 16:02:37 »
Hi, mine is the mini facelift but the coding procedure may be the same, according to my manual it states :- 1) Switch on ignition.  2) Switch off the radio using the off switch.  3)Press and hold the CD key.  4) Switch on the radio while keeping the CD key pressed until you hear a confirmation beep.  5) The display shows "CD-CODE" for approx 3 secs, then "CDC code:" and the number of remaining attempts, for example "---- (10)". 6) Enter CD changer code number with the number keys.  7) Confirm "OK" by pressing multi-function control knob.  Hope this helps.
« Last Edit: 14 January 2007, 16:03:15 by philayl »
Re: stereo problems
« Reply #3 on: 14 January 2007, 16:21:16 »
CCR2006 does not have a seperate CDC code. This is a fault with the unit apparently...
zywiec
  • Cambridge
Re: stereo problems
« Reply #4 on: 14 January 2007, 16:34:43 »
I was mistaken on my original post the display is saying 'CDC SAFE' not 'CDC CODE'.
@ the boy is this something that can be repaired (probably at the stealers) or is a new one needed?
zywiec
  • Cambridge
Re: stereo problems
« Reply #5 on: 14 January 2007, 16:36:32 »
thanks for the reply I tryed this with no joy get as far as stage 4 but there is no beep.
i cant find any seperate description in the owners manual for my modile
« Last Edit: 14 January 2007, 16:37:07 by zywiec »
Re: stereo problems
« Reply #6 on: 14 January 2007, 16:41:54 »
Seems to be common enough, wait and see what others say what they did when theirs failed...
dragon33
  • swansea
Re: stereo problems
« Reply #7 on: 14 January 2007, 18:37:20 »
safe means that you have entered the wrong code a certain number of times,radio needs to be on for anything between 2 mins and 2 hours as the code is time locked
Re: stereo problems
« Reply #8 on: 14 January 2007, 19:29:39 »
Also means code hasn't been entered.
zywiec
  • Cambridge
Re: stereo problems
« Reply #9 on: 14 January 2007, 19:54:57 »
the code hasnt beeen entered wrong in the last month, and it say's this only on the cd mode the radio and cassette work fine
dose any one know off any good stereo service places in the bournemoth area as i think this needs to be looked at profesionally
dragon33
  • swansea
Re: stereo problems
« Reply #10 on: 14 January 2007, 19:59:39 »
doesnt matter when the codes were entered wrong,these radios have a memory chip iin them as do the changers which infinitely stores code info.
Re: stereo problems
« Reply #11 on: 14 January 2007, 20:10:23 »
The CDR2006 (or any of the Double DIN units) do not have seperate codes for CD Changer, as the changer is in the head unit...
zywiec
  • Cambridge
Re: stereo problems
« Reply #12 on: 14 January 2007, 21:09:25 »
so if the code has been entered wrong to many times how do i get it reset??
dragon33
  • swansea
Re: stereo problems
« Reply #13 on: 14 January 2007, 21:20:03 »
you need to leave the radio on until safe changes to ----10 eg .the lockout time depends on how many times the codes been entered in 2minute increments eg.2,4,8,16,32 etc up to a maximum of ten times,its worth a try,also ignition needs to be on
dragon33
  • swansea
Re: stereo problems
« Reply #14 on: 14 January 2007, 21:25:06 »
Switch ignition on.
switch unit off.
Press AS and switch unit on.....
" CODE" appears after 3 secs, 10 ----.
or try this
