CCRT 700 instalation in 98 MV6 non Bose?
Started by Autobahnstormer, 02 March 2007, 16:54:41
Autobahnstormer
 Guess this has been asked, but cant find the post, but will a CCRT 700 work with my non Bose system and will it plug and go? I have a 600 unit at the mo in my 1998 MV6? If its to much work I will just get a car kit. Thanks in advance of any help.
Dean
I am looking to do this too... I have a aerial on the roof at the back of my 98 elite so i am hoping it will swap right over??
Hope we find an answer..did a search but not much help.
Dean
Free Traffic law advice  - Just PM or see the sticky thread in General Chat ! http://www.omegaowners.com/forum/YaBB.pl?num=1177278724 - no liability accepted
Autobahnstormer
I also dont know if we need a screen change to handle the phone information or if it will work with what we have? I am sure someone knows, fingers crossed.
the 7000 has its own display, won't work with others.  I think the Bose setting is software via Tech as per later NCDC series...
sounds2k
#4
to my knowledge, on the CCRT700's the difference is in hardware - the bose versions (line level instead of speaker level outputs) have bose on the cassette door, normal versions do not. The normal versions will work fine with a non-bose setup.
the correct display for the CCRT700 should look like this (mobile phone signal strength, etc should be in bottom right of display) :
It's the facelift NCDC series that have this setting in software (ie programmed via TECH2)
.... but I could well be wrong!!  ;D
Quoteto my knowledge, on the CCRT700's the difference is in hardware - the bose versions (line level instead of speaker level outputs) have bose on the cassette door, normal versions do not. The normal versions will work fine with a non-bose setup.
Hmmm, could be :y
Dean
Sorry , I am confused now...
Can we sum up whether concensus of opinion is that it can ..or cant be done.
What will happen if I simply replace my BOSE CCR800 unit with the CCRT700 Bose unit?
Regards
Dean
QuoteSorry , I am confused now...
Regards
Dean
Probably a radio that will work, but no phone. I wouldn't think it'll be worth the effort. New GID & microphone required for a phone that's a good 7 years old. Get a decent hands free installation for your hand held mobile.
Dean
Well i won the auction for the CCRT700, will see how i get on when it arrives..
If it dont work straight back on eBay.. will get my money back i think!
Dean
Just to clarify another option...
I have purchased the ccrt 700 to replace my bose ccr800.
I have the MID screen, so apparently the phone wont work with it?
If i was to buy a GID screen (the one that works with the ccrt700) would i just need to get it coded to the ccrt700?
then get a mic obviously...
