Help Please Im Confused Now !!
Started by ANDY250862, 09 May 2007, 05:28:50
ANDY250862
Got 2 Electric window switches kindly sent by mark   :y. but now i am really confused. also bought 2 off E-bay (with blue leds) tried the 2 from Mark and the drivers side one will not go up or down so unplugged it and tried the one off E-bay and that is the same so put the original  one that i had in there and that works but with the original problem that the up button makes window go down. Can you please help its driving me daft now to the point i may have to get an Auto Electrician out to it and that costs £££££££££££ >:(
If you press the up button many times (shirt sharp bursts) does the window go up?
If yes, lube the window runners...
ANDY250862
No. As i said earlier when i use the fob to lock the doors and keep it pressed for a short while the window goes up no problem which tells me that motor is ok. but just baffled that the original switch that was in there was faulty and went down now matter which way switch was pushed. And the 2 that you sent me the drivers one does nothing at all and the 2 new ones off e bay are the same :(
