Pages: 1 [2] 3  All   Go Down
Author Topic: Tech 2  (Read 15220 times)
Re: Tech 2
« Reply #15 on: 23 July 2007, 19:02:30 »
Wil keep trying  on and off, but does anyone have any ideas?
The problem with non-standard serial ports is that, rather than using the serial port as intended, the cheapo tech2 uses a couple of the handshake lines and "bit bashes" them in software, using timing loops and other evil to generate the required waveforms with the required timing.
If the machine is directly connected, through a simple driver, to a real UART the calls the code makes to change the state of the handshake lines translate into immediate (or pretty much) transitions of the pins at the serial port. If the driver is actually piping the commands over a USB port, for example, the timing gets totally messed up and it's unlikely to work.
PCMCIA is an unknown quantity in that, in theory, it's a bus so you could implement a serial port by hanging a proper UART off the bus. Who knows what they're actually doing, though? The problem is the timing of the handshake lines are not normally that critical in a real serial port due to large buffers either end, so a bodged port is likely to be lacking in this respect.
Has the interface you have worked with a "real" serial port? That would be my starting point, get it working with a machine with a genuine serial port and then compare the timing of the waveforms you get.
Mike Collins
  • North of Bristol
Re: Tech 2
« Reply #16 on: 23 July 2007, 22:33:03 »
So far I have been unable to find a pulse train on any of the connected pins in the diag connector, looking with a 'scope, so not got as far thinking about the interface.
Am I missing something obvious?
Re: Tech 2
« Reply #17 on: 24 July 2007, 08:08:01 »
Are you trying this while connected, or away from the car?
I Believe the tech2 gets its power from the diag socket, so you would need to emulate that as well
Sorry if i'm teaching egg sucking!
Mike Collins
  • North of Bristol
Re: Tech 2
« Reply #18 on: 24 July 2007, 08:22:34 »
Looking directly at the diag port on the car with an oscilloscope, I have not found a pulse train on any pin, the Hungarian software appears to tell you which ALDL pin it expects to see data.
I'm sure I'm missing something obvious.
Re: Tech 2
« Reply #19 on: 24 July 2007, 08:42:59 »
So, have you actually 'asked' the port to send data?
As far as I know it works like this
Tech2 plugged in, gets power from socket
Tech2 Asks For data
Car supplies Data
Tech2 displays response
It reads like you are trying just to read the port without asking for anything?
Apologies if I have misunderstood your problem
Re: Tech 2
« Reply #20 on: 24 July 2007, 09:37:38 »
I agree. Without a Tech 2 or similar to initiate communications I wouldn't expect to see any activity on the diag port.
Mike Collins
  • North of Bristol
Re: Tech 2
« Reply #21 on: 24 July 2007, 14:32:13 »
That sounds exactly like what is happening, anyone know what form the tech2 request takes?
The nearest information I have found is that 10K to ground on pin 6 pulls that line to +5V and enables ECU communication mode.
It passes the quiet moment.
Re: Tech 2
« Reply #22 on: 24 July 2007, 15:02:12 »
There's a whole bidirectional serial protocol that's implemented by one end or other pulling the line down to 0v or letting it float and then waiting for the other end to acknowledge / respond.
The documentation is probably around on the internet somewhere if you really want to get into it, although I think most of it is based on an ISO standard and you have to pay for them >:(. Getting any life out if it at all would be a non-trivial exercise, however.
There are projects like this: http://freediag.sourceforge.net/ if you really want to get your hands dirty!
Mike Collins
  • North of Bristol
Re: Tech 2
« Reply #23 on: 24 July 2007, 16:59:58 »
Thanks Kevin, that seems to fit what I am finding. I have just tried an ALDL serial interface cable, powered on the bench, but not connected to the car. When the "Hungarian" software searches, the data line pulls down to ground briefly.
I suppose the next step is to try connecting that data line to pin 6 on the car and see if it provokes a response.
Probably a good thing car is not here at the moment, my head hurts.
Re: Tech 2
« Reply #24 on: 24 July 2007, 20:26:58 »
Remember that the Hungarian software controls a multiplexer between the max and the car, which should select right line.
VX1
  • Reading, Berkshire
Re: Tech 2
« Reply #25 on: 24 July 2007, 22:20:50 »
So what code reader would I need for a 1995 Omega?
http://www.talktomycar.co.uk/Shop/Code_Readers/Code_Readers.htm
Vx Trade club card holder
Halfords trade card holder
Re: Tech 2
« Reply #26 on: 24 July 2007, 22:24:27 »
None, a paperclip will do engine.
If you want to do other stuff, a Tech1 (around £500 - £700 secondhand), or a Tech2(really from 97 on, around £2k)
VX1
Re: Tech 2
« Reply #27 on: 24 July 2007, 22:28:29 »
Thankyou.  :y
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: Tech 2
« Reply #28 on: 25 July 2007, 14:46:28 »
Or Opel Autoscanner about £250 ish
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
Re: Tech 2
« Reply #29 on: 25 July 2007, 15:00:19 »
They got that properly working on pre 97 cars?
Pages: 1 [2] 3  All   Go Up
