Author Topic: Installing the original radio in my MV6, Need help  (Read 6436 times)
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
« on: 12 August 2007, 19:42:12 »
Hello,
Right today I decided to install the original vauxhall radio back in to my MV6, as with the after-market one you can't use the digital display on the dash, so when I un-installed the aftermaket one this is what I found, any advice, any idea's;
[size=14]I'm sure there is something missing at the end of this cable;[/size]
[size=14]And further down the same loom half the cable have been cut and is missing,[/size]
[size=14]And these cables where already cut, the cables stick out from behind the ashtray, bottom-right. I'm not sure if they have anything to do with a telephone kit;[/size]
[size=14]And these cables where taped down to the top of the climate control, one on each of the back of the temperture display's and are sealed at the ends[/size]
« Last Edit: 12 August 2007, 19:45:34 by jim »
Re: Installing the original radio in my MV6, Need
« Reply #1 on: 12 August 2007, 19:57:23 »
Looks like some idiot cut through autochanger loom....
Jim
  • Glasgow
« Reply #2 on: 12 August 2007, 20:13:23 »
Which photo, the second one?
« Reply #3 on: 12 August 2007, 21:25:53 »
Yes
    • 530D M Sport, 330i Coupe
« Reply #4 on: 12 August 2007, 21:46:08 »
The blue and black wires with sealed ends are the Y antenna for the Trafficmaster IIRC
Jim
  • Glasgow
« Reply #5 on: 12 August 2007, 22:55:01 »
Cheers Mate, I didn't know that. Are they supposed to be taped to the back of the climate control unit.
« Last Edit: 12 August 2007, 22:55:30 by jim »
« Reply #6 on: 12 August 2007, 23:33:26 »
Imagine so, (I knew what they were from my vectra - they were taped to the top of the glovebox in that) they need to be stretched apart - like those cheapie FM aerial's you used to get with cheap jap midi systems!
Jim
  • Glasgow
« Reply #7 on: 12 August 2007, 23:48:27 »
I never would have guessed they where for the traffic-master, cheers for that :y
Anybody got any ideas how to repair whats left of the radio cables, so that I can put the original radio back?
« Reply #8 on: 14 August 2007, 22:33:34 »
I reckon the best thing you can do is get a loom (or as much of a loom as possible) from a scrapper and cut what you've got back to a point before the phantom slasher got to it then attach your salvage loom to it with soldered and shrink wrapped connections.
I think the wires in picture 3 may be the trafficmaster loom (For power, mute and audio). If you search for traffic master on ebay i'm sure you'll find a picture that shows the loom.
The bit you think is missing from picture 1... shouldn't that connector have a third row of connections? Possibly for the MID?
« Reply #9 on: 14 August 2007, 23:09:53 »
I agree. Looks likle the 3rd connector was broken off the moulding and the wires cut (and not insulated :o) to make the ISO connectors fit an aftermarket head unit.
You need to at least get the missing connector. May as well get a section of the loom and graft it on.
Jim
  • Glasgow
« Reply #10 on: 15 August 2007, 09:52:48 »
Cheers Kevin, I'm of down to the scrappie today so I'II see what I can find  :y
MartinP
  • Dudley
    • BMW 320D
« Reply #11 on: 15 August 2007, 21:14:41 »
If you have no luck I've got a complete wiring loom from a 98 GLS, in a box, under a desk, in my garage  ;)
Jim
  • Glasgow
« Reply #12 on: 18 August 2007, 16:45:09 »
How long is the complete loom for the radio system?
MartinP
  • Dudley
    • BMW 320D
« Reply #13 on: 21 August 2007, 20:38:19 »
I'll drag the loom out and check
