Author Topic: Speedo Problems  (Read 2623 times)
Flinty
Speedo Problems
« on: 25 August 2007, 15:13:38 »
Can any one shed some light please, I have a 2.5 Omega estate on the R plate, but the speedo is not working, it did last week for about 20 mile then gave up te ghost again.  I have had a new sender unit fitted to the gear box at a cost of £140 but this made no difference. :-/
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: Speedo Problems
« Reply #1 on: 25 August 2007, 20:57:53 »
Are your ABS and TC lights illuminated on the dash??
If so, its going to be either your rear near-side ABS sensor (but you said was replaced?) or the ABS module itself (sell your soul to satan to afford to replace/repair that...)
Humbugs...
Dazzler
  • Haverhill, Suffolk
Re: Speedo Problems
« Reply #2 on: 25 August 2007, 21:13:14 »
If it is the ABS module then BBA reman repair yours for about £125 inc vat and postage, and a garage should charge about 3hrs to replace. So not to bad.
If you have no other lights, suspect clock itself, i had to change mine for this reason.
Just a quick check(if no other lights) give the clocks a good shove in to make sure the push in multiplug is all the way home.
HTH.
Re: Speedo Problems
« Reply #3 on: 25 August 2007, 21:46:58 »
I can personally vouch for the service BBA-Reman offer .. they tested, confirmed the fault, and repaired my unit on a 5 day turnaround, from garage despatch to receipt (couriered monday unit couriered back friday).
All for £125 and a 2 year warranty ... excellent service IMHO
Page created in 0.008 seconds with 16 queries.
