Author Topic: Omega Colour Display (CID)  (Read 10170 times)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« on: 04 October 2007, 10:06:43 »
I have posted on CID problems before and have just received a display from Germany. Display is working fine but image is upside down and main dealer struggling to find out next step - i.e. is it software or screen fault -  awaiting reply from German seller but can't contact him til later today. Trying to see if anyone out there has experienced this and is there a fix?. Will try also with Vauxhall.
Update
Screen working and flashing intermittently "display safe" (but still upside down)  - seems to need a code - so effectivelt Tech 2 not effective until I get a code from somewhere - Vauxhall do not know what to do so waiting to speak to supplier. Interesting.
phil
« Last Edit: 04 October 2007, 12:45:57 by pscocoa »
    • 530D M Sport, 330i Coupe
Re: Omega Colour Display (CID)
« Reply #1 on: 04 October 2007, 13:01:45 »
Don't you have to 'unmarry' (Divorce!!!) the old CID unit from the Head Unit first before you can 'marry' the new CID to the Head Unit?
Whatever happens then you definately need TechII somewhere along the line.....
pscocoa
« Reply #2 on: 04 October 2007, 13:36:45 »
That's a very good point - thank you - will ask the garage but they should know to do this but then again....!!
much obliged
Phil
Danny
  • Wigan, Greater Manchester
« Reply #3 on: 04 October 2007, 14:20:08 »
even in cars, adultery is not acceptable!
which one gets custody of the CDs??
    • E250 Est / Elroq
« Reply #4 on: 04 October 2007, 14:20:31 »
I Think you have unwittingly bought an Australian Model.
Go there and It will be the right way up  ;D
pscocoa
« Reply #5 on: 04 October 2007, 14:42:21 »
Yes - the australian point has already been made - and yes I can see the funny side - dealing with Vauxhall you have to!!
« Reply #6 on: 04 October 2007, 15:11:19 »
The Display flashing SAFE means the display is in delivery mode.
You need to unpair your radio from your old display (via Tech2), and repair to new display (via Tech2).  Immobiliser code needed.
No idea why its upside down though - no software setting I know...  ...assmuning you haven't mounted it upside down ;)
pscocoa
« Reply #7 on: 04 October 2007, 15:17:44 »
Thanks - we are just debating whether to unscrew the back and turn the unit round as the holes seem to match up - either way - this may correct the inversion. Trying to get seller's consent.
Thanks - when I get this sorted will do a summary of difficulties faced with Vauxhall and Siemens who have proved very ineffective and do not have a regime to deal with these faults cost effectively. And yet in Germany there are organisations specialising in these repairs. Most retuned electrical items for Vauxghall go to AEL in Birmingham for repair but they will not touch anything sat/nav related.
Phil
edwardmickey
  • Milton Keynes
« Reply #8 on: 04 October 2007, 15:40:18 »
If I recall correctly, if it flashes, 'display safe,' it can be coded with Tech2 using your car pass.
If it remains on 'display safe,' then you have a problem as it needs unpairing from the head unit it was originally fitted with.
« Reply #9 on: 04 October 2007, 15:43:43 »
Sounds right :y
pscocoa
« Reply #10 on: 04 October 2007, 20:01:04 »
Just returned from garage with old unit refitted - (colour scheme has now changed eg red bose logo not visible but colour sat nav ok if still intermittently faulty- will have to follow up tomorrow).
The replacement unit has apparently baffled Vauxhall and they now say it is possibly because the part is from Opel. The unit is identical to the original one in the car and is the part number per Vauxhall - KJ fittings exact
The dealer says there is no need to depair the original unit as that function is just for removing the head unit from the vehicle? Apparently Tech 2 computer will not allow an Ident code.
Question out there if anyone is able to help or is there a tech2 genius who I can ask to help?
Have spoken to supplier - unit came from an Astra G - he beleives that a code is required for my vehicle - the only codes I have on the  vehicle pass are the VIN, Security Code and serial no. of the radio.
Service manager advises thast it flashes "display mode" previously hwe thought it said "safe mode".
I need someone who knows which end is up with this stuff.
Phil
edwardmickey
  • Milton Keynes
« Reply #11 on: 04 October 2007, 22:21:44 »
TheBoy sorted out my CID with his Tech2; mine was flashing 'Display Safe' and needed my radio four digit code to be programmed with the Tech2 on the CID.
After that, there were options to set it for Opel or Vauxhall logo; options to have black background or light grey.  The light grey is how it should be set as per the Omega brochure; when headlights are switched on, the Vauxhall logo changes from white to yellow.
Your CID is in delivery mode.  Your ECU knows the four digit code for your headunit.  This is printed on your car pass.  The Tech2 is used to program the CID to the same four digit code as the headunit - should work then.
PM TheBoy, if he can't help, nobody can.  Vauxhall Dealers are useless, they only ever use the Tech2 to plug in and read fault codes, charging fifty quid for the pleasure!!
It can be done......just need Tech2 and someone who knows what they're doing  ;)
« Reply #12 on: 04 October 2007, 23:08:38 »
Therein lies the problem with most of the dealers.
BigCat
  • Battersea
« Reply #13 on: 05 October 2007, 00:38:22 »
I'm assuming that the module is going in the correct way i.e. large connector towards the centre air vents, and the smaller connector towards the steering column.
There are a few possibilities:
    * The screen could have been fitted into the housing upside down - very difficult to do, as the short ribbon cable that connects the LCD to the printed circuit board isn't long enough to do that.
    * The LCD module inside does have the capability to flip upside down, although it needs a different voltage on two of the wires on the aforementioned ribbon connector. Specifically pins 5 and 6 should have their voltage held high. If low, the display will flip.
    They could be low as a result of a broken wire/ bad connection etc. Thats the sort of thing any TV repair type place can fix for you.
    * You say the replacement came out of an Astra. Does anyone know if the Astra display is mounted upside down compared to the Omega?
    [/list]
    The first 90% of a job takes 90% of the time, the last 10% takes the other 90% of the time.
    pscocoa
    « Reply #14 on: 05 October 2007, 00:52:39 »
    Thanks for the input - there is a lot of confusion not helped by Vauxhall's dealer support set up.
    I am contacting someone off the site who can possibly assist but the inverted image is a concern and I will have to be careful not to invaidate warranty by removing seal. Will be a shame if I have to return the unit.
    Once again many thanks
    Phil
