Cruise Control - Brake Pedal Switch Where Is It?
Started by Jim, 08 October 2007, 16:44:41
Jim
Hello,
I've just removed a crusie control system from a 98 3.0 v6 elite but I coundn't find the brake pedal switch, can someone please tell me exactly where it is,
cheers Jim
Dazzler
Jim
Dazzler
No.............Its up under the dash mounted on a bracket at the top of the brake pedal.
Jim
I'm retro fitting the cruise control system to my 1998 mv6, I know that all the plugs are under the bonnet for the system but is the stalk just one for one, plug and play.
Also does the brake pedal switch also just plug in or do I have to remove anything else from the donar car to make it work
Dazzler
Actuater and bits under the bonnet, brake and clutch switches and as you say swap over the stalks..
Jim
QuoteActuater and bits under the bonnet, brake and clutch switches and as you say swap over the stalks..
Cheers Mate :y
Make sure right stalk - 2 wire for 2.5TD, all others 4 wire.
Jim
QuoteMake sure right stalk - 2 wire for 2.5TD, all others 4 wire.
Cheers  :y
Jim
#10
[size=16]Ok, I've found the pedal switch and it has four wires coming from it, is this the correct one to use with the cruise control system or do I have to fit another one[/size]
ffcgary1
Jim if the switch has 2 pins but 4 wires then you need to change the brake switch to a 4 pin  switch. if the switch is 4 pins then you are good to go as they say.
Jaguar XJ6
Jim
QuoteJim if the switch has 2 pins but 4 wires then you need to change the brake switch to a 4 pin  switch. if the switch is 4 pins then you are good to go as they say.
Ok it did have 2 pins but 4 wires thought I wouldn't have to change it :(, no problem I'II get the correct switch from the doner car tomorrow now that I know where it is, cheers mate :y
ffcgary1
#13
Jim you need to push the "keeper" in to allow the switch to be removed, but do not play with the switch when out as the plunger  will have a working position as such. if you have any problems  with the switch pm me as i have a spare [new] up for grabs.
Regards, Gary.
Jaguar XJ6
Jim
QuoteJim you need to push the "keeper" in to allow the switch to be removed, but do not play with the switch when out as the plunger  will have a working position as such. if you have any problems  with the switch pm me as i have a spare [new] up for grabs.
Regards, Gary.
Cheers Mate, I'II let you know how I get on tomorrow :y
