Dashboard Illumination problem
Started by DJ Pete, 13 October 2007, 18:48:49
DJ Pete
Hello all,
Strange one this, changed my headlamp switch today, as the old one had a cracked pcb and wouldn't adjust the headlamp height.
After putting the new one in (second hand), everything seems to work fine apart from when I turn the lights on, the MID goes blank, and the dash illumination fails to work, I tried wriggling the brightness control, but still nothing.
So, could be a faulty new switch, I put the old one back in, and the same is happening.
Is there a fuse for the dash illumination hidden somewhere? I've checked all the fuses in the fuse box and all are ok.
A wiring diagram might help, does one exist?
Thanks in advance,
Pete.
wiring diag in haynes manual if you have one...
brett1408
i had the same thing in a senator, on that it was caused by 2 thin metal prongs each side of the illumination adjustment wheel that were'nt quite making contact, not sure if omega's are the same but worth a look!
DJ Pete
Sorted.
I took the switch apart, cleaned everything up and made sure it was seated correctly, and now it works perfectly.
Thanks!!
