Author Topic: Head Unit ignition / constant power - how to swap?  (Read 2274 times)
JayUK
  • Cardiff
« on: 10 November 2007, 20:47:32 »
I've replaced my previous sony unit with a Blaupunkt HU. Currently it 'forgets' the time and track place when I turn off the ignition - What wires do I need to swap over?
I'm using the autoleads adapter. The Sony unit had a 2 bullet connectors you could just swap over, simple idea but effective!
Anyhoo - Any help to stop my Blaupunkt forgetting? :)
« Last Edit: 10 November 2007, 20:48:08 by JayUK »
Re: Head Unit ignition / constant power - how to s
« Reply #1 on: 10 November 2007, 20:59:26 »
Await an expert to confirm this .. but I believe on vauxhalls the permanent live is the wrong way round and 2 wires have to be swapped to enable the memory to be retained.
Give it a while and someone will tell you exactly which 2 wires it is .. :)
« Reply #2 on: 10 November 2007, 23:06:58 »
Swap permenent 12v and switched 12v
uktigger
  • Blackpool, Lancs
    • 2003 2.2 Omega CD
« Reply #3 on: 11 November 2007, 00:33:35 »
usually the red and yellow if i remember correctly
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
« Reply #4 on: 11 November 2007, 00:56:08 »
Here you go mate. http://www.omegaowners.com/forum/YaBB.pl?num=1185108720
This thread starts off a little obscure but should answer your question.
[size=24]        [/size][/b]
