Author Topic: N/S front door lock  (Read 2729 times)
m0rmh
  • kendal
    • 2.6 elite
N/S front door lock
« on: 23 November 2007, 08:30:17 »
THe front door lock (N/S) does not work, a few weeks ago it worked sometimes but now i can't pull the button up manually so the door is now perm locked any ideas............. Mike   :(
CyNick
  • Monmouthshire
  • Car is stuck in KIDDERMINSTER!!
Re: N/S front door lock
« Reply #1 on: 23 November 2007, 18:05:17 »
I've got the same problem.. Except mines not jammed locked!!
...well it was but it's now open and I can manually open and close it..
What needs changing??
NICK
m0rmh
  • kendal
    • 2.6 elite
« Reply #2 on: 23 November 2007, 18:12:35 »
Hi Cynick, door managed to unlock today so hopefully on sunday (25/11) will strip door and check what the problem is, and it may help you........mike  :y
« Last Edit: 23 November 2007, 18:15:03 by m0rmh »
Mike Collins
  • North of Bristol
« Reply #3 on: 23 November 2007, 18:13:06 »
If the motor is not running, probably a microswitch inside the door lock motor is high resistance when closed.
If you remove the motor you can dismantle it and check, or change the motor.
You do need to be able to open the door though.......
m0rmh
  • kendal
    • 2.6 elite
« Reply #4 on: 23 November 2007, 18:31:51 »
I'll strip and check the motor. if it is the microswitch where can i get replacement, Up here Kendal has nothing........
ghondie
  • sheerness,kent,uk
  • Looking for work, any offers?
« Reply #5 on: 24 November 2007, 09:54:53 »
hi, same problem here. seems that the gearing in my locking motor has lost a few teeth, works occasionally but most of the time not at all. its good fun taking the door appart , but getting to the motor is a nightmare, obviously people that do it more often may have easy ways of doing it.
as for the door dead locking, i managed to pull hard on the lock and eventually it came open, will so often deadlock again but now i know how to open it its not a problem.
now just need to get a replacement, i could risk getting one from a breakers, you could even use the ones from a later ed saab, as they are the same pn
anybody got a cheap supplier?
cheers
Man with a mission. not sure what it is but i've got one
Sheerness Lifeboat Crew and ILB Mechanic
