Author Topic: RADIO PROBLEMS  (Read 4566 times)
EGGY2
  • N.IRELAND
RADIO PROBLEMS
« on: 29 November 2007, 21:16:27 »
Was wondering if any one could help me, my battery went flat and cleared my radios memory. it keeps saying radio safe, does anyone know how you go about getting the code. its a philips ccrt 700 cheers. :y :
    • 530D M Sport, 330i Coupe
Re: RADIO PROBLEMS
« Reply #1 on: 29 November 2007, 21:20:41 »
Code is printed on the Car Pass, if you haven't got it then best to speak to the dealers or a car audio specialist who can decode it.
EGGY2
  • N.IRELAND
Re: RADIO PROBLEMS
« Reply #2 on: 29 November 2007, 21:33:08 »
Where abouts on the cars pass?
Missy_MV6
Re: RADIO PROBLEMS
« Reply #3 on: 29 November 2007, 21:51:19 »
If you do find the code then there is a sequence to putting into the radio....My hubby has just had to do it for a friend with an Astra.
If you don't have the code you have to remove your radio and get the numbers that are stamped into the casing on the radio. Also the numbers that are on the white sticker on the radio and then register on the following site. Give them all the relevant numbers and they should get back to you with a code and how to enter it.
Good Luck
Angie x
http://www.31bubblegum.proboards54.com/index.cgi
« Last Edit: 29 November 2007, 21:53:13 by Missy_MV6 »
Re: RADIO PROBLEMS
« Reply #4 on: 29 November 2007, 21:53:57 »
You will also need a code for the multi CD player as well.
Missy_MV6
Re: RADIO PROBLEMS
« Reply #5 on: 29 November 2007, 22:04:15 »
Oh yeah forgot to mention that  :-[...You may find that your cd changer wont work either..Just do the same thing ..remove and get all the numbers off it. Post on that site I gave you and fingers crossed they should get back to you with some codes.The site is totally free
Angie x
« Last Edit: 29 November 2007, 22:04:40 by Missy_MV6 »
davlad22
  • Sunny Yorkshire
Re: RADIO PROBLEMS
« Reply #6 on: 30 November 2007, 15:23:09 »
Here you go mate (provided you have the all important radio code!);
http://www.omegaowners.com/forum/YaBB.pl?num=1185223347
For the CD changer (if you have one) instead of holding 'AS', hold 'CD' instead. (Though it might be fine without inputting the code)
EGGY2
  • N.IRELAND
Re: RADIO PROBLEMS
« Reply #7 on: 03 December 2007, 20:23:02 »
Would like to thank everyone for their help. Got the radio code this morning cheers.. :y
