Author Topic: Coolant - whats going on  (Read 2817 times)
« on: 07 February 2008, 19:46:04 »
You may recall I have coolant loss from the K series Rover, and a monumental coolant leak from the MV6.
Now, I have done nothing of consequence to fix these, other than try to investigate location/cause.
Both appear to have stopped leaking completely.
Re: Coolant - whats going on
« Reply #1 on: 07 February 2008, 19:46:36 »
Has the radweld fairy been to visit?
« Reply #2 on: 07 February 2008, 19:47:50 »
Nope.  As said, I've done nothing of consequence.
    • 530D M Sport, 330i Coupe
« Reply #3 on: 07 February 2008, 19:49:15 »
Have you disconnected then reconnected any pipework?  :-/
« Reply #4 on: 07 February 2008, 19:49:15 »
Wasnt meaning you!
No way does that description fit!
Maybe 'she' wants attention instead of the cars so has taken matters into her own hands  ;D
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #5 on: 07 February 2008, 20:01:28 »
Have you got any water left in ? ;D
« Reply #6 on: 07 February 2008, 20:02:23 »
Not related to likely leak areas  :-/
Dazzler
  • Haverhill, Suffolk
« Reply #7 on: 07 February 2008, 20:02:32 »
Very good............i can see why you lost your post count ;D
« Reply #8 on: 07 February 2008, 20:03:58 »
Yup.
Only difference is that it is milder now, rather than the frosty temps at the weekeknd
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #9 on: 07 February 2008, 20:05:04 »
Yup.
Rather weird :-?
« Reply #10 on: 07 February 2008, 20:10:48 »
Well metal does contract when cold, making that core plug weep more than normal  :-?
Phil
« Reply #11 on: 07 February 2008, 20:49:57 »
On the MV6 it could be your HBV, mine has a def leak, BUT only does it when the climate control is set below 21!
After about 10 mins it throws water everywhere, turn it to hot, or turn it off and it wont use a drop of water for thousands of miles stick it on anything below 21 and itll go through 2ltrs of water in 60 miles!!
Not sure if its also linked to my air con not working due to the 'top up' valve leaking
Just my 2p worth
« Reply #12 on: 07 February 2008, 21:01:11 »
Just my 2p worth
HBV was my first check - looks sound :y
miggy
« Reply #13 on: 07 February 2008, 21:17:51 »
Yup.
Rather weird :-?
Who...you. ;D ;D ;D ;D ;D
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #14 on: 07 February 2008, 22:20:16 »
If you had leaks, did nothing and the leaks stop.....they will return  :(
