Amplifier choices
Started by Martin_1962, 11 January 2008, 18:03:57
Martin_1962
Does anyone know anything about MacAudio or SPLX in car amplifiers, or Blaupunkt?
Thanks
Craig_R
sorry no but i do know about pioneer ones as i fitted a nice 4 channel 280w one to mine
Mod's
[To be Fitted]Reverse Sensors
Nathv6
not sure too b honest but it really depends on ya budget and what you are thinking of running with the amp????
Martin_1962
Infinity 605CS and 1 amp FOC
Nathv6
whats them m8 dnt do model numbers lol too many to remember
Admin
Splx = Nasty cheap garish chav amp. Big claims and low quality (and price). Not recommended.
MacAudio = Slightly better than Splx. Again, not recommended.
Blaupunkt = Better.
If you are looking to run a set of Infinity 605's (up front I presume) then I would suggest a 2 channel amp producing around 30-40w rms.
You don't need more than that.
I would also recommend a small sub to get the best out of the system.
Here are some recommended amps going cheap.
http://cgi.ebay.co.uk/Alpine-V-Power-2-1-channel-amp-MRP-T130-tested-working_W0QQitemZ230210049449QQihZ013QQcategoryZ18796QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/Alpine-MRV-T707-Car-Audio-Amplifier-Boxed-Good-Con_W0QQitemZ260200951877QQihZ016QQcategoryZ18796QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/Kenwood-Power-Amplifier_W0QQitemZ260200528093QQihZ016QQcategoryZ18796QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The Administrator.
I was quite impressed with the amp design of the Kenwood KAC unit I fixed for Mr Laidback.....
QuoteI was quite impressed with the amp design of the Kenwood KAC unit I fixed for Mr Laidback.....
I had a pair of Kenwood amps (about 25W RMS per channel, so not big power, but plenty) back when I used to do such things.  While I make no comments on their design (never took them apart), they sounded great. And still do - I fitted the system (Kenwood HU, 2 amps, 10 disc changer, all from around 1992) in Mrs TheBoy's dads Rover a couple of years back...
Martin_1962
QuoteSplx = Nasty cheap garish chav amp. Big claims and low quality (and price). Not recommended.
Blaupunkt = Better.
They are all on Freecycle - so are FOC - which youls you have?
Admin
If it is free, then I would have the Blaupunkt... no guarantees it will work though.
All the amps I have suggested will be very cheap (under £25 I expect) and will drive the Infinity speakers quite nicely.
The Administrator.
Martin_1962
Martin_1962
Blaupunkt is quite good - looking at pairing two channels
Admin
I would presume that it is a 4 channel amp then. Make sure it can be bridged.
The Administrator.
Craig_R
Blaupunkt = Better.
If they are free grab them all Ill have one off you i need a second amp which is duel or single channel  ::) ::)
Mod's
Martin_1962
Macaudio if not good enough would be yours
I'll test bridging the BP
Freecycle is a good way of getting rid of unsellable stuff - eg old potties, and getting otther peoples old stuff - like wood for rabbit hutches
