Auto dimming mirror
Started by amba, 27 January 2008, 13:57:59
amba
Have tried to fit my newly bought auto dimming mirror this morning and am a bit puzzled by the wiring required.
The mirror has a large plug on the back with several connections and different clours of wiring.As my car is 1998 elite(but has sports leather seats without memory and only standard mirror)hoped that the wiring would be in place .
Whe I removed the interior light all I could find was a female white plug with two wires going into it..brown/white and  black .the plug was fitted to the inside of the sunroof switch trim with a small push in trim clip.I was hoping to find a purpose wired connector so that it would plug straight into the mirror..no such luck.
Can anybody guide me as to what I need or do I just need an extra section of wire from a breaker ?If not is it just a connection into the white plug and then just 2 wires into the mirror.
Hope that all makes sense
Tafty
I had similar problems to yours - I ended up getting connectors that can be piggy backed  - got mine from halfrauds - I then connected to the pos + and neg - of my sunroof - Though If I remember correctly the wiring was a bit bizarre with the black being positive and brown being Neg/Ground  . Follow Hilpers guide and will see you through :y
amba
Thanks Tafty..expect the white plug I am referring to is + and grnd,but as you said colours are strange so will put a test light on..my main issue was the pin connectors on back of the mirror and if you could buy small enough pin fittings..saw Hilpers guide which is great..he used computer connections so may look at Maplins for a bit of pre wired cable
Quote..... Though If I remember correctly the wiring was a bit bizarre with the black being positive and brown being Neg/Ground  . Follow Hilpers guide and will see you through :y
Usuall Vx wiring.
Black being ignition switched live
Red .... permanant live
Brown .... ground as you say.
amba
Andy B..any idea what the white plug I found under the headlining is for then..has 2 wires only..assume as wires seem to match as suggested will be ok to just connect up ??but could do with the section of wire with plug
QuoteAndy B..any idea what the white plug I found under the headlining is for then..has 2 wires only..assume as wires seem to match as suggested will be ok to just connect up ??but could do with the section of wire with plug
You won't have any suitable connectors up there unless yours was fitted with memory seats.
3 connections can be made from courtesy light, 4th from passenger kick panel
amba
TB..why do I need 3 ..don,t I need just feed from ignition and ground ?Hilpers guide does indicate can connect to reversing light but hardly seems worth it..Also what is the 2 wire connector with the white female plug for then ??any ideas
QuoteTB..why do I need 3 ..don,t I need just feed from ignition and ground ?Hilpers guide does indicate can connect to reversing light but hardly seems worth it..Also what is the 2 wire connector with the white female plug for then ??any ideas
The connector you have found is nothing to do with it. If yours didn't have the factory fitted memory seats, you don't have the required loom. So improvise off the courtesy light.
3rd wire is to prevent dimming if courtesy light on.
Reverse wire is a safety feature so you can still use mirror when reversing without it dipping.
amba
But Hilpers guide only shows 2 wires.which colours do I connect to which colours on interior light.his only shows red/black...also where does the reversing connection go..seems that colour is pink on mirror but where do I connect the wire that I feed down to passenger kick-panel .Thought this was a simple "plug,n,play.
QuoteBut Hilpers guide only shows 2 wires.which colours do I connect to which colours on interior light.his only shows red/black...also where does the reversing connection go..seems that colour is pink on mirror but where do I connect the wire that I feed down to passenger kick-panel .Thought this was a simple "plug,n,play.
Autodip mirror is not plug and play. A small amount of work required.
From courtesy light you can give switched live, light on, and 0v.  From passenger footwell you can get the reverse.
Hilpers guide lists the colours on the mirror loom, but be aware there are multiple wires with same colour, and they are not interchangable!
amba
So just to clarrify..3 connectionsrequired to mirror for it to function...1 is permenant live...1 is switched live with ignition..1 is ground..?is that correct ?? then if reversing feature required wiring down to kick plate
QuoteSo just to clarrify..3 connectionsrequired to mirror for it to function...1 is permenant live...1 is switched live with ignition..1 is ground..?is that correct ?? then if reversing feature required wiring down to kick plate
switched 12v
0v
'light on' signal
reversing signal
1st 3 from courtest light
amba
Sorry to be a bit fick..do you mean "light on" signal as 12 volts permenant on.I am ok with the rest now
Doh! It's been a loong day!  :-[  :y
amba
Tell the truth it has been a looooong month,have worked every day since 1st jan and a bit tired..but that is another story.
Hillpers guide ,which would seem to be the definitive set of instructions,only mentions a switched +12volt and a ground.It clearly shows 2 wires being connected from mirror and the same 2 being connected to the sunroof plug.
So why do I need to make 3 connections excluding the reversing light option should I wish to include this ?
Does the mirror require a constant unswitched 12 volt + as well as a switched ignition as well,Dont want to connect up and blow or damage circuit so would like to be totally certain.
