Author Topic: Mondays V6 Lifter change  (Read 1299 times)
« on: 08 February 2008, 13:35:51 »
Couple of quick phone shots:
1)  Camshaft coming out. note the spring has come out of the oil seal. (And it's easier to remove the sprocket before the cam!)
2) Sucking out a lifter with a valve griding stick:
3) State of the engine oil already, in my newly refurbished head...
Re: Mondays V6 Lifter change
« Reply #1 on: 08 February 2008, 13:36:53 »
And yes, I realised half way through I had no kitchen roll in the inlet ports ;D
« Reply #2 on: 08 February 2008, 14:14:43 »
bloody hell just realised something.... when i did the same on my project LPG, there was NO oil around the top of the lifters..... yours is swimming in it.
Might have explained the rough running  ::)
They look a tad better than mine too!  ;)
« Reply #3 on: 08 February 2008, 14:20:02 »
There should be a liberal amount of oil under the cam covers. The oil fed to the cam bearings and the lifters should just pee out and lubricate the cam lobes by splash before draining back to the crankcase.
If it was dry under there (and it had run relatively recently) it doesn't bode well.
I guess this is how a camshaft came to go rusty...  ::)
« Reply #4 on: 08 February 2008, 14:24:23 »
someone elses problem now  :-X
« Reply #5 on: 08 February 2008, 14:45:44 »
Sold as a dog?
If yours was that dry I would have popped the sump pan off......
« Reply #6 on: 08 February 2008, 14:55:21 »
Ahh. Anyone we know?  :o
« Reply #7 on: 08 February 2008, 15:14:26 »
No. But if a oppsed Elite LPG turns up soon you did not know me  ;)
« Reply #8 on: 08 February 2008, 15:20:45 »
I just tried buying an Elite, but failed....
Taxi_Driver
« Reply #9 on: 08 February 2008, 20:42:28 »
Sold as a dog?
But on the bright side.......the cam cover gaskets wont fail and pee oil into the plug wells  :D ;D
« Reply #10 on: 08 February 2008, 20:56:55 »
Sadly, I saw lifter change and thought it was a 'coming out' thread!
