Author Topic: Camshaft sensor went..replaced and went again  (Read 2107 times)
glyno
« on: 29 January 2008, 21:21:01 »
...after 2 miles.
I had problems with the sensors last year..all replaced (3 I think?) and all ok until last week.  The EML came up and it was the Camshaft sensor again.  Had it replaced, but came up straight away....took it straight back to the garage where they say it must be a 'deeper' electrical problem.  Has anyone had a similar problem...a friend mentioned that it could be that the sensor wasn't fitted properly??  P.S. I know nothing about cars, so if anyone has a layman's explanation.
Omega Estate 2L 16V 1999T (170K)
Re: Camshaft sensor went..replaced and went again
« Reply #1 on: 29 January 2008, 22:05:55 »
check cam timing
« Reply #2 on: 29 January 2008, 22:06:20 »
also, was it genuine sensor, pattern ones appear to be unreliable
The Doctor
  • Wolverhampton
« Reply #3 on: 30 January 2008, 22:20:58 »
might be worth gettin a tooth brush and some WD40 on the old half of the wiring, give it a good clean.
« Reply #4 on: 31 January 2008, 10:56:32 »
What EXACTLY is the code being indicated.....not Camshaft Sensor Incorrect Signal per chance?
