Author Topic: CCR600 in "Safe" mode  (Read 3792 times)
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« on: 03 February 2008, 14:57:29 »
Afternoon gents,
Ive got a CCR600 in the mega but it shows "Safe" on the display, I was under the impression that it means it's goosed and some one has got the code wrong 10 times...
I have the code it and the CD changer, is it worth doing any thing with it or should I ditch it for some thing newer ?
« Last Edit: 03 February 2008, 14:59:10 by JonArgraig »
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
Re: CCR600 in "Safe" mode
« Reply #1 on: 03 February 2008, 15:14:00 »
Forgot to add, I've tried holding "AS" down for about 15 secs on nothing happend
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 03 February 2008, 16:57:36 »
Check you are turning on the ignition first -
Code Entry as Follows:
Turn Off Stereo
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
If codelocked - leave powered for two hours and try again, and if you need it resetting and decoding, then send it to me via this link
http://ice.dndservices.co.uk/shop_show_item.php/MID/39/ISS/20/IID/3037/PAGE/shop_decode_index.php
 8-)
Radio & Decoding Technician
www.dndservices.co.uk
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #3 on: 03 February 2008, 17:03:14 »
Thanks for that, I think its locked though, Ive held the AS button in for a while and nothing happend. well I'll give it go again later and if need be I'll get in the post
« Reply #4 on: 03 February 2008, 17:09:53 »
The AS has to be held down whilst the power is switched on, then for about 3s after
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #5 on: 03 February 2008, 17:15:44 »
I had held in for a good 20 secs with the ign on, I'm starting to think maybe the head unit is goosed
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 03 February 2008, 17:28:38 »
Nope, just used up all of the code entry attempts
Send it over - no problems at all
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #7 on: 03 February 2008, 17:34:21 »
May well send it over,  just toying with moving the DVD player from the mondeo, just its silver (matchs the ford dash) so it might look a tad gash,
Any one had the plesure of fitting screens to the head rests in a mega ? much room to work in them?
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #8 on: 03 February 2008, 22:17:34 »
I'm a village idiot...
Cleaned up the contacts on the removable panel, only just noticed it didnt light up...
and now it works fine
You may now begine the mocking
waspy
« Reply #9 on: 03 February 2008, 22:20:49 »
Mocking, mocking  :P :P
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #10 on: 03 February 2008, 22:35:24 »
« Reply #11 on: 04 February 2008, 10:34:14 »
The cheapest fixes are the best :y :y
Now, let the piss-taking begin ;D
