CD changer help!
Started by VX1, 24 January 2008, 19:01:33
VX1
Hi all,
I have a cd changer in the elite but is doesn't work at the moment, I was told it just needs the fuse putting in, BUT where is it? Is it under the steering wheel in the fuse box or else where?
Thanks in advance
Paul  :y
Vx Trade club card holder
Halfords trade card holder
Admin
Not sure about the fuse... but you have checked the power supply is plugged in haven't you?
The Administrator.
waspy
This may sound a little obvious, but isn't the fuse on the back of the changer, it is on mine.
Which changer is it? Blaupunkt or Phillips?
Dave DND
Without knowing details of the equipment being fitted, I can only offer the following.
Not all Blaupunkt and Philips changers are cross compatable, so make sure you have the correct one for your head unit.
The head unit must be disconnected from the power whilst the changer is being connected and power must only be restored when everything is plugged in. This is so the head unit will recognise the changer when first booted up, if plugged in afterwards, it may not recognise it.
Radio & Decoding Technician
www.dndservices.co.uk
VX1
QuoteNot sure about the fuse... but you have checked the power supply is plugged in haven't you?
Haven't checked but will check. Was told it needed a fuse by the last owner.
VX1
QuoteThis may sound a little obvious, but isn't the fuse on the back of the changer, it is on mine.
Have looked nothing there.
VX1
QuoteWhich changer is it? Blaupunkt or Phillips?
Not sure. I think it's the standard one fitted to the 3.0ltr Elite P reg 1997, if that helps.
VX1
QuoteWithout knowing details of the equipment being fitted, I can only offer the following.
Its The vauxhall fit head unit and the cd changer, if thats any help.
Dave DND
Others on the forum may be able to add to my database, but for the Omega, I have 14 variations of head unit and 11 variations of CD changer.
All would be classed as Standard Fitment !
You need the correct changer for the head unit, not just a "Vauxhall" one!
CD changer has fuse in cabin fuse box. Cant remember number (see M_DTM post in Tech Info), but its bloody obvious - labelled something like 'CD' rather than the icons the other fuses use :)
VX1
Right have checked the fuse box under the steering wheel No 4 is for the CD changer, NO FUSE. The cable for the cd changer is all there from the changer and connected. The changer is phillips and the radio is phillips as well. The stero is the SC 804 CD and the changer is the DC012. Is the radio compatible with this cd changer?
Dave DND
VX1
QuoteShould be compatable
Good. Now next question
Why won't it switch on and why isn't it ejecting the cd magazine? What do I need to do to get it working?
Dave DND
Sounds like it may be knackered !
You appear to have tried everything else !!
