Amp works speakers next
Started by Martin_1962, 09 February 2008, 21:35:49
Martin_1962
Put in the LHS speaker cable and the 12v power supply, spent ages feeding the trigger cable and stereo out from foot well to head unit. Ended up using my flexible picking up thingy to drag draw cable through from HU slot to by steering wheel cowling (after removal).
Temporarily wired up the Infinitys to the loose wires - sounds loud but no real test when sat on the ground. Listened to Doctor Doctor and Only You Can Rock Me.
The original wiring is still live so will use amped feed with Infinitys when fitted, VX just use HU amp.
Next job is make room for XOvers in arm rests, swap the speakers and reconnect the amp to the battery.
The amp cable has followed the fridge and LPG cables down the left cill.
So my car has down left
Amp +12
Fridge/Charging +12
Tank Solenoid +
Fuel gauge +
Combined LPG -
Speaker pair
Right
CD Control & Power
CD to HU in stereo pair
HU out to Amp stereo pair
Trigger cable for amp
Speaker pair
Dazzler
A tad busy with wires then Martin????
Martin_1962
QuoteA tad busy with wires then Martin????
Over two years, started with tow bar wiring
Dazzler
Still haven't wired mine up yet :-[
Have you managed a sub amp as well as Bose before??
Martin_1962
Mines all after market stuff SOny MD & CD Changer and Infinity speakers
