ncdc 2015
Started by paul36uk, 11 February 2008, 09:50:51
paul36uk
hi all,i have a 2001 omega mv6 saloon with a 2015 head unit,i have just got hold of a bose amp for it ,does anyone know which new leads or looms i need to get or any other advice i will need to get the job done?
many thanks
You need the main loom that runs from the drivers kick panel to the Bose amp.
Plus the rear shelf speakers.
And you might want to swap the door speaker out as they are 2ohm instead of 4 so the amp can drive them a bit harder.
Then the head unit needs Tech2ing in order to put it into Bose mode.
Was the 2015 factory fit?
paul36uk
yes it is a factory fit 2015,ive got four bose door speakers too,i know i need to get two rear subs,
do you know where i can get a loom?
cheers
Quoteyes it is a factory fit 2015,ive got four bose door speakers too,i know i need to get two rear subs,
cheers
From any breaker with bose fitted, it is a seperate loom.
paul36uk
would the loom have to be from a facelift or ar the connections to the amp the same?
Quotewould the loom have to be from a facelift or ar the connections to the amp the same?
From all the ones I have seen, they are the same.
paul36uk
many thanks for your help  :y
zirk
Hi Paul,
Welcome to the Site. A lot better in here!
Zirk (Chris)
I'm guessing the saloon/estate looms vary, but not prefacelift/facelift.
paul36uk
do i have to remove the headunit to acess the connections or are they in the drivers well like someone kindly said?
sorry im no mechanic
Quotedo i have to remove the headunit to acess the connections or are they in the drivers well like someone kindly said?
There in the drivers footwell......the dash loom is the same for bose/non-bose
paul36uk
i dont suppose by any chance the loom is already installed at the factory?
No, only on Bose systems, hence why its a seperate mini loom that only does bose  :y
paul36uk
