After market head unit
Started by Doodley, 05 February 2008, 22:28:48
Doodley
if i install an aftermarket head unit, will the track display still show on the dash screen (e.g above the fuel consuption computer)? and will it work with the standard CD changer (philips DC012)? cheers if you can help!
Martin_1962
Depends and no
You can get display adaptors for some radios
Doodley
ok cheers, also one more question, i have an elite, and it has 2 subs in parcel shelf (although not the bose setup i dont think) if i buy a new head unit, will this work ok with the subs, as i asumme the subs already in the car have an amp, and the new Head unit will have amplified outputs aswell? will two amplifiers cause conflict as such?
omegamonkey
Quoteok cheers, also one more question, i have an elite, and it has 2 subs in parcel shelf (although not the bose setup i dont think) if i buy a new head unit, will this work ok with the subs, as i asumme the subs already in the car have an amp, and the new Head unit will have amplified outputs aswell? will two amplifiers cause conflict as such?
Aren't the speakers on the rear shelf just plain passive bass drivers, not subs? If so, changing the head unit will still drive them using existing wiring.
If they're genuine subs then they must have either crossovers wired in somewhere along the line or the head unit has a dedicated sub out channel.
My '99 CDX has Vx loom wiring with a multiplug on the end hanging from just under the parcel shelf so I presume it had something there at one time but no speakers under the shelf and the pre-cut speaker cut-outs in the metal are intact. Not sure if an amp was removed or it's standard to have the wiring hanging there in case it's needed (doubtful)?
jules
Are you talking about a four pin connector hanging out of the shelf on the left hand side ? From memory I think it has +ve ground and switched ?
I think that's for the rear blind
Hotel21 wrote 'Its doubtfull in the extreme if it is the head gasket at fault.  If it were burning 5 litres per week the car would leave a smokescreen behind it!'
