Towbar wiring connector in boot
Started by alexandjen, 10 February 2008, 15:30:17
alexandjen
Has anyone got a wiring diagram for the connector which is behind the rear panel in the boot as I need to hard wire a new 12n socket?
Original wiring a bit of a bodge with scotchlocks everywhere  ::)
Trade club card holder
Code scanner available
QuoteHas anyone got a wiring diagram for the connector which is behind the rear panel in the boot as I need to hard wire a new 12n socket?
There's loads of towbar & wiring info here somewhere. Have a search!  ;)
Big_Roger
Hi All,
This is what I checked out from wiring digram in Haynes Manual in readiness for fitting a tow bar and electrics to my 3.2
Connector XA is round connector in rear of boot.
1 Left dir indicator    wire Black / White
2 Fog light               wire Black / Blue
3 Fog light               link (or switch inside socket to turn off fog lt)
4 Right dir indicator  wire Black / Green
5 Right rear light      wire Grey / Red
6 Stop lights            wire Black / Yellow
7 Left rear light        wire Grey / Black
8 Reverse lights       wire White / Black
9 Supply positive      wire Red
10                           )
11                           ) Preume not used (can't find on diag)
12                           )
13 Supply negative   wire Brown
HTH
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
Quote.......
6 Stop lights            wire Black / Yellow .......
Just remember though that the brake light feed if fed from this socket is via another trailer brake check 'relay' up front behind the glove box (above driver's feet in earlier cars).
alexandjen
Quote.......
So do you need the relay or can you short two terminals on the socket?
Or splice into feed wire to brake light?
If you break into the wire and "splice " it in any way.. you'll probably end up with a permanent "brake bulb failed" warning, the warning is all based on circuit resistance AFAIK. Thats why I had to buy the fancy "Flash Guard" control box at £54.50 + vat ( TC price through AndyC - give him a ring he's damned good !)
alexandjen
#6
Isn't the relay which fits behind the glovebox cheaper at about £16 or could I not just short the socket terminals?
I am assuming that once this relay or piece of wire is in place that the brake live feed wire to the boot socket becomes live?
QuoteIsn't the relay which fits behind the glovebox cheaper at about £16 or could I not just short the socket terminals?
Yes to all! Or as you say take the supply from the actul brake lights. I just mentioned the feed to prevent you from scratching your head wondering why the the trailer plug in the boot was dead.  ;)
alexandjen
Nice one thanks Andy  :y
I'll take the feed from the actual wire to the o/s brake light via a 7 way bypass relay  :y
