Cruise control not working.
Started by Kate, 10 February 2008, 15:26:20
Kate
Hi.  Does anyone have any idea why cruise control might not work?  I've checked the fuse and it seems ok.
Thanks very much.
Kate
QuoteHi.  Does anyone have any idea why cruise control might not work?  I've checked the fuse and it seems ok.
Thanks very much.
Kate
Brake pedal switch? - there are 2 sets of contacts
Yes......check the brake pedal switch....one trick is to pull the switch plunger out whilst the pedal is pressed.
Kate
Thanks.  Sorry for being stupid but where would the switch be?
QuoteThanks.  Sorry for being stupid but where would the switch be?
Behind brake pedal - its quite high, and you need to remove the cardboard panel to get to it...
vesil
The wire that goes to the cruise button on the indicator stalk might be cut, from years of using the stalk. It should be visible if you pull out the rubber surrounding it a bit.
Or cable to cruise actuator broken...
I have seen both these things happen.
Kate
Thanks very much! I'll have a look.
If it is the switch they're not too dear. I'd to buy one last year as mine wouldn't let me change from P when I wanted to. A bit embarrasing at the lights. :-[
Kate
zirk
Also if its a Manual Box, check Clutch and Gearbox selctor Switch, and sometime the actual stalk switch plays up.. try pressing it a bit harder than you need to.
zirk.
Kate
Thanks. I'll try that as well.
markomega25
I have the same problem on my 2.5 Auto. so useful to see if you get yours sorted Kate.
Mine has never worked since I got the car a year ago. I recently asked the main Stealer to check it (whilst doing MoT). They did a Tech 2 and said it was not giving any fault codes and asked if any work had been carried out before (I had no idea), they wanted another £105 to explore further for an hour, so I left it.
Will check switch but if it is the actuator/motor does a replacement need a tech 2 install?
Quote....... but if it is the actuator/motor does a replacement need a tech 2 install?
No. That's for the later cars that are drive by wire.
Kate
What does drive by wire mean? Mine's still not fixed yet. :(
jules
Three questions :
Has it ever worked ?
Are you riding the clutch a little ?
What speed are you doing when you try and activate it ?
Cheers
Hotel21 wrote 'Its doubtfull in the extreme if it is the head gasket at fault.  If it were burning 5 litres per week the car would leave a smokescreen behind it!'
