Author Topic: out side temp display  (Read 8772 times)
zippo
  • manchester
« on: 27 January 2008, 19:01:09 »
when i put the face plate on the stereo (jvc) the mid turns on and shows f in the left corner and c in the right.With the car being new to me i've only just noticed that the m.i.d doesn't display the out side temp at all, has anyone come across this before
 tia  daz
philayl
  • Wirral, Merseyide
Re: out side temp display
« Reply #1 on: 27 January 2008, 20:53:11 »
Hi, it will show the outside temp automatically when the temp drops below 3deg centigrade. You can also get it to display the temp by scrolling the info using the bottom(I think) button on the end of the right hand stalk on the steering column.
zippo
  • manchester
« Reply #2 on: 27 January 2008, 21:25:21 »
there isn't a temp read out  on the display at-all even when i use the stalk thingy just f n c .
philayl
  • Wirral, Merseyide
« Reply #3 on: 28 January 2008, 12:52:35 »
Sounds like you have a faulty sensor, one of the electrical geniuses should be along shortly to give some advice on what to do next.
zippo
  • manchester
« Reply #4 on: 28 January 2008, 13:58:58 »
not got a clue tbh, i'll probably end up at the dealers with it
darren
« Last Edit: 28 January 2008, 14:01:24 by zippo »
philayl
  • Wirral, Merseyide
« Reply #5 on: 28 January 2008, 19:13:27 »
darren
If you are ever round the Widnes area I can recommend Andy Stockton at www.asautocare.co.uk he is an independant Vauxhall specialist.
zippo
  • manchester
« Reply #6 on: 14 February 2008, 18:23:16 »
up date the f in the left corner stands for fault c in the right corner celcius but their should be an auto check system as well engine oil, coolent,atf, etc and that isn't being shown chap who looked at it today seems to think it has something to do with the after market stereo that's fitted so its back to the drawing board  >:( >:( >:(
« Reply #7 on: 14 February 2008, 18:34:44 »
FYI, bought one today for the father in law
Part no : 9152245, £7.85 retail, £5.89 trade club, both plus vat
zippo
  • manchester
« Reply #8 on: 14 February 2008, 18:36:26 »
ive just pulled the stereo out and there's a plastic wiring block not connected to anything could that be apart of the problem ???
« Reply #9 on: 14 February 2008, 20:42:02 »
.....ive just pulled the stereo out and there's a plastic wiring block not connected to anything could that be apart of the problem ???
To the display from the OE radio?
zippo
  • manchester
« Reply #10 on: 15 February 2008, 00:41:17 »
do you mean the sensor
« Reply #11 on: 15 February 2008, 10:37:28 »
Yes, new sensor.
seems to be the same sensor across the whole Vauxhall range
zippo
  • manchester
« Reply #12 on: 16 February 2008, 03:11:45 »
Yes, new sensor.
cheers jimbob :y :y
