Help...Climate fan running on....
Started by woody68, 16 February 2008, 18:24:16
woody68
Just need some help plz to sort out a problem i've got with an 94' elite the fan keeps running on the heater panel even when you've taken the keys out ....the fan speed number is only just visable too
can stop it if i take fuse out ,but don't want to keep doing that really ...lol
Any help most welcome guys thank you ...
Phil
have to got (or had) damp passenger footwell carpets?
woody68
Hiya m8 the footwell is not wet or damp at the moment but i only just picked the car up on weds last, so it could have been before that date...??
The heating works fine hot and cold..... just this damn fan running none stop ..... :(
Mike Collins
If it's climate control, then fan controller has failed. It's mounted in the fan casing, have to remove glovebox for access.
The early controllers may be repairable, most likely one power mosfet has shorted.
QuoteIf it's climate control, then fan controller has failed. It's mounted in the fan casing, have to remove glovebox for access.
agreed, likely due to blocked scuttle drain
woody68
Just to confirm i've got the right bit ....this is the fuse i have to remove to stop fan running on.....
fuse ,33-30A Heater fan, air-conditioning system.....
so if i go behind glovebox , I'll be looking in the right area...???
sorry to sound thick but new to omega's.... ;)
Mike Collins
With the glovebox removed, look up and you should see the fan casing. The controller has two heavy gauge wires and several thinner ones. You may have to remove two vacuum switches to give clearance, if it hasn't been removed for a long time it may be a bit stuck.
QuoteJust to confirm i've got the right bit ....this is the fuse i have to remove to stop fan running on.....
speed controller is bolted to blower, which you'll see when you get glovebox out.
woody68
Cheers guys for the heads up..... :y
Will have a look tomorrow at work....getting the glovebox out is easy enough is'nt it ...?? their not boobytrapped are they..... :o
;D
QuoteCheers guys for the heads up..... :y
;D
Not as easy as expected, and officially should disconnect battery as you have to loosen airbag.
woody68
[/quote]
Not as easy as expected, and officially should disconnect battery as you have to loosen airbag.[/quote]
Aaahh so they are boobytrapped..... ;D
GKJones
Hi Phil
I had a similar problem on my old 96 OmegaB, I used to pull the fuse as well and the fix was the regulator unit behind the glove box connected to the fan from what I remember.
It was a bit of a bum to get to and I think the replacement part was about £90 so a bit risky but it fixed mine.
Good Luck
Greg
