Author Topic: Face-lift remote switches source.  (Read 6789 times)
« on: 21 February 2008, 12:12:02 »
« Last Edit: 21 February 2008, 12:23:01 by Mark »
Martin_1962
Re: Face-lift remote switches source.
« Reply #1 on: 21 February 2008, 12:49:23 »
Ordered :y
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #2 on: 21 February 2008, 18:20:05 »
Available from RS under the following code:
102-361
See here:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=102-361
What are these for?
« Reply #3 on: 21 February 2008, 19:45:13 »
The switches in the remote fobs start to fail with age, the extra force required also kills the rubber outer!
Martin_1962
« Reply #4 on: 21 February 2008, 19:58:43 »
If I repair mine permanently I'll look at doing them for members
Danny
  • Wigan, Greater Manchester
« Reply #5 on: 21 February 2008, 21:26:28 »
keep me updated!
Albatross
  • Bedford
« Reply #6 on: 21 February 2008, 21:54:16 »
keep me updated!
Tick
Martin_1962
« Reply #7 on: 21 February 2008, 23:40:58 »
I am looking at this also to help pay my debts off - won't be rip off but I will need to charge - I'll do mine first then work out prices.
« Reply #8 on: 22 February 2008, 10:13:16 »
Just fitted a set and they work great.....also fit in most later Vx remotes (ie corsa etc)
The rubber on the buttons gets mushroom shaped with use before they start to fail!
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #9 on: 22 February 2008, 11:34:19 »
Update me too, please.
« Reply #10 on: 22 February 2008, 12:33:31 »
102-361
See here:
Will they suit prefacelift as well?
« Reply #11 on: 22 February 2008, 12:53:50 »
102-361
See here:
No, they are a different (and higher quality) type....
Martin_1962
« Reply #12 on: 22 February 2008, 14:10:20 »
102-361
See here:
Which one is the better one?
« Reply #13 on: 22 February 2008, 14:39:13 »
The early switch is better quality but, to big to fit in a three button remote!
Note, the replacements from RS are C&K and not ITT as per the original ones so are actualy better quality anyway (ITT switches are not great but, very cheap)
Martin_1962
« Reply #14 on: 22 February 2008, 15:09:36 »
Well I now own quite a few switches so will offer to repair them for members .
I will charge sensible rates as I am broke, but good at soldering.
3 new switches per keyfob with return recorded post will be £7.50 for members with at least 100 posts.
2 Keyfobs same packet would be £12
One member can have them a lot cheaper since I cleaned them before.
New members or non members will be £10.
Please note : postage is not cheap from RS, and it does take about 30 minutes to do properly.
Just send the fob section, and a return address I can sellotape on, in a jiffy bag.
Send it recorded, I use it as they don't tend to disappear then!
PM me for details :y
Now to join some other forums ;D
