water comeing out of battery
Started by f13platform, 02 March 2008, 21:27:14
f13platform
when car is warm water cant stay in battery
they just come out out of the top
any one know what s tha ?
(no EML- no electrical problem-car start first time -drive fine)
just too much acid water from battery ruin my pipe >:(
thank u
GastronomicKleptomaniac
Overfilled? IIRC, it should only be covering the top of the plates.
Dave DND
Sounds like it may be overcharging and boiling the water if it only happens when running?
Suggest to get the charging circuit checked asap, to eliminate it if nothing else.
Radio & Decoding Technician
www.dndservices.co.uk
QuoteSounds like it may be overcharging and boiling the water if it only happens when running?
I agree. Maintenance free batteries (like all modern ones) don't vent nor need topping up unless they are abused. Measure the voltage across the terminals at a fast idle. More than around 14.5 and you've got problems. If left, it could damage other parts of the electrical system too.
f13platform
thank u to all for ur help
i empty the water a bit and eveything seam fine
and volt meter show 13.9 - 14 when car was runing
i ll wait few day to see what happen
Quotethank u to all for ur help
Whats the voltage at 3000rpm with most of the major electrical loads off?
f13platform
i didnt try that
i ll try that  :(
