Omega 2.2 DTI engine electrical fault
Started by shakey j, 29 February 2008, 18:47:27
shakey j
Hi all,
I've just developed an engine electrical fault on my 2001 estate (Only owned the car a week!) The light seem's to come on when the car is warm and once on the car goes into what I think is a safe mode and the rev counter stops working?
I realise that I will have to get the ECU checked for error codes but does this sound like a common (Or expensive  ::)) fault and does anyone know a good auto electrician in South Birmingham?
Cheers,
Mark
Stick your car details and location in your profile .. saves being asked a zillion times !!  :)
If you have a 2.5 V6 you can paperclip it to get codes
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
stevief
The 2.2 DTI does not respond to the paperclip test or a lo of the generic code readers.
You need either proper tech 2 or one of the better generic readers to get the diagnosis right.
If it comes up with a fuel pump not getting a speed signal problem try the crank sensor before changing the pump.
Best of luck,
Steve
shakey j
QuoteThe 2.2 DTI does not respond to the paperclip test or a lo of the generic code readers.
Best of luck,
Steve
OK thanks Steve,
Would the crank sensor be affected by heat? I have diven the car 3 or 4 times now and the error has appeared after 3 miles each time?
Mark
shakey j
#4
Would THIS be worth getting?
Best of luck,
Steve
OK thanks Steve,
Mark
Sorry, dont know about 2.2DTi ones. Certainly v6 ones are often heat related...
shakey j
It's somewhere to start cheers  ;)
shakey j
After reading through this I think I will try changing the crank sensor. Where can I pick one up at a reasonable price?
Vx part number 90540188 £34.95+Vat retail (£26.21+Vat trade club)
shakey j
QuoteVx part number 90540188 £34.95+Vat retail (£26.21+Vat trade club)
Thanks  ;)
shakey j
Crank sensor fitted and all sorted  :) Thanks for all the help  :y
Mark
