CDR400 code entry prob...
Started by Erthe, 21 April 2007, 12:38:17
Erthe
Ok, so silly mistake I Left my ignition on overnight, don't ask me why as I dont know  :(
Jump started the car and off to work I go. Go out to the car at break time and realise that radio is in safe mode. No problem, I know the code! (famous last words) Usual method, hold AS etc...
I enter the code and find that maybe my memory was not what it once was  :(
I try again....no joy  :(
Ok, thats me on 8 SAFE...I aint gonna play around, will wait till I get home
I get home and locate my correct code and try that...as I am trying it I get a beep and now it says 7 SAFE...geez I was having a bad day!!   I stop rushing and go to try again. Now all I get though is 7 SAFE and can't get it to bring up the 4 dashes for me to input the code  :-/
Have I done something wrong? what could I have done?
It definately says 7 SAFE and I definately have the correct code...but it just wont let me input it.
Any suggestion?
There is likely to be a time delay of half an hour or more.....plus you need the ignition on....
Yep.....just checked, heres the detail
After the first two attempts, the waiting time is approx 10 seconds...after this it increases to ten minutes....with each further un-succesful attempt, the waiting time doubles reaching 640 minutes by the 9th attempt...
Erthe
Is this the waiting time between attempts? or the duration of waiting till it gives you the chance to put the code in? ( as in holding AS)
Thx
QuoteIs this the waiting time between attempts? or the duration of waiting till it gives you the chance to put the code in? ( as in holding AS)
Thx
between attempts, and ignition needs to stay on. Turning ignition off resets the timer back to zero, so you have to wait the full time again.
Are you sure the code is right?
Erthe
Yeah, code is definately correct (was just me trying to be clever that couldn't remember it)  :-/
So my understanding now is that the timer resets when I turn the ignition on and I then need to wait for it to time out before trying?
As it is on 7 SAFE I pressume this will not be too long? will trying before this time is up reset it again? or is just ignition linked? (as I have no idea how long to wait before trying hehe)
Going to try after the 10 minute run to work tomorrow (before I turn the ignition off hehe)
Thx guys
QuoteYeah, code is definately correct (was just me trying to be clever that couldn't remember it)  :-/
Thx guys
The ignition must be on for the entire timeout period, and then the code entered...
Darth Loo-knee
TB asked if you put in the correct code.....
I made the same mistake to be honest as on the "Car Pass" on the line I have
Radio Type/Code 4442     C/D 2147
and I was putting in the wrong number in out of the two!! :-[
Erthe
As I said, was not giving me the option to put the code in  >:(
But tried as was suggested this morning as I went to work
and now I have sounds again!!!!
Thx guys much appreciated   :y :y :y
Took about 10 mins before it let me
QuoteAs I said, was not giving me the option to put the code in  >:(
:D
MikeDundee
Right I have the manual but it does'nt list the CAR400 stereo, so what buttons must I hold in and press to enter the codes????
Dave DND
Code Entry as Follows:
Turn Off Stereo
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
Radio & Decoding Technician
www.dndservices.co.uk
MikeDundee
QuoteCode Entry as Follows:
Turn Off Stereo
It's OK just done it - thanks :y
Same for the entire CAR400/CCR600/CCR800 range, and is in Maintenence Guides ;)
