Author Topic: CCR 2006 mute wire  (Read 5599 times)
The Cambelt Kid
  • Derby
CCR 2006 mute wire
« on: 29 March 2008, 22:03:19 »
Hi Guys,
Just installing a Sony bluetooth carkit into my wife's corsa, the last owner installed a ccr2006 so i suppose it's sort of linked to an omega.
Anyway i can't seem to locate the audio mute cable in the corsa's wire loom to the radio, so i removed the radio to investigate.  I can see that one of the wires on the power block does not have wire going to it.  The one that is missing has symbol of a triangle inside a square.  I'm guessing this is the mute wire, which GM though wasn't needed on a poxy corsa.
Please can anyone confirm this is the mute cable?
Cheers
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
The Cambelt Kid
  • Derby
Re: CCR 2006 mute wire
« Reply #1 on: 29 March 2008, 23:19:08 »
I may have found the resource i was after...
http://www.akirwan.freeserve.co.uk/akhow2/ice.rtf
Looks like i was correct with pin 6 (triangle inside square)
Cheers
The Cambelt Kid
  • Derby
« Reply #2 on: 30 March 2008, 00:28:50 »
Seems i was wrong!  Every time i make a call the light on the cd go out and the audio from teh radio does not mute.
I have a sneaky feeling that the audio mute wire is (or should) be connected to the other connector next tot he speaker connector block.  does anyone have a pinout for this at all?
Cheers
« Reply #3 on: 30 March 2008, 10:28:54 »
Pin 34 Black 0.5mm
The Vx pin numbering varies from that diag often posted on here, the aux in is 35 and 36, so 34 is next to them
HTH
The Cambelt Kid
  • Derby
« Reply #4 on: 30 March 2008, 20:55:31 »
Pin 34 Black 0.5mm
HTH
Thanks TB,
I'll just pop out and try it...
The Cambelt Kid
  • Derby
« Reply #5 on: 30 March 2008, 21:14:53 »
Just pulled the head unit out and can't find pin 34... unless i count up from pin 1 of the power block and then onto pin 16 of the audio block, so then id be starting the 3rd block at pin 17 to 36.
Would i be counting the pins correctly this way?
Cheers
« Reply #6 on: 30 March 2008, 21:48:22 »
Looking at plug, 36 is top left, 30 top right
The Cambelt Kid
  • Derby
« Reply #7 on: 30 March 2008, 22:29:09 »
http://www.ccpip.org/800/service/Connctn.html#CCRt700
Managed to sus it out with this diagram.  I make it out to me pin C13 and it seems to give 'message' on the screen permanently, with or without a call...  Does this tally up with you TB?
Cheers for your time  ;)
« Reply #8 on: 30 March 2008, 22:31:13 »
Yes, C13 = pin 34
Mike Collins
  • North of Bristol
« Reply #9 on: 31 March 2008, 21:28:00 »
I tried fitting a Sony bluetooth to my 2.6, its mute line was not man enough to pull the line down. Tried helping it with shunt resistors to no avail, gave up and refitted the Nokia bluetooth.
Mine could be defective, or is this common?
« Reply #10 on: 31 March 2008, 21:41:28 »
Sony, what do you expect?
Mike Collins
  • North of Bristol
« Reply #11 on: 01 April 2008, 21:28:59 »
Yes, I should have known.
It doesn't auto answer or switch profile like my Nokias.
Pretty case though.
