Author Topic: New bulb for sunroof controls  (Read 4359 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 24 April 2008, 16:44:58 »
Looking at a few small jobs that i need to do one of which is to replace the buld in the sunroof control. How easy is this to do and has any one done this before. Would be nice to have it working again.
Thanks
Steve.
Re: New bulb for sunroof controls
« Reply #1 on: 24 April 2008, 16:55:28 »
From memory on previous threads ... it is do-able but slightly tricky as on some the bulbs are soldered in .. looking at the EPC I would guess they ALL are ... bulb has 2 long trailing wires and no cap .. :(.. although it could be a push-fit like christmas tree lights I suppose ...
The Doctor
  • Wolverhampton
« Reply #2 on: 24 April 2008, 19:58:47 »
i decided to replace mine with a resistor and diode (or just use a 12v diode) so that i wouldnt ever have to do it again.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #3 on: 24 April 2008, 20:51:32 »
Bulb is just a push fit on mine. The wires slide into the contact housing.
TuBy's new whipping boy.
« Reply #4 on: 24 April 2008, 20:56:00 »
same as mine .... I discovered that only when I'd removed the whole motor & it was sitting on the dining room table.  :-[  :y  :y
SP_3.2
  • Leicester
« Reply #5 on: 24 April 2008, 22:58:48 »
Thanks all will give it a good look over at the weekend. :y
    • 530D M Sport, 330i Coupe
« Reply #6 on: 24 April 2008, 23:02:56 »
I think you can get an equivilent from Maplins (about 500% cheaper than VX)
sdwall
  • Walsall
  • Nil illegitimum carborundum!
    • '03 2.6 V6 CDX Auto Est.
« Reply #7 on: 11 June 2013, 13:49:37 »
I've got some 4.7mm 12V 100mA 1.2W Wire Ended lamps that fit (with just a little bit of fiddling) as a replacement for the sunroof control backlight. It is quite a fiddly job though because the two legs of the bulb are quite flimsy. Certainly works now in mine. So if any one's interested let me know and I can pop a couple in a jiffy bag.
    • E250 Est / Elroq
« Reply #8 on: 11 June 2013, 14:05:05 »
Cough Cough cough,,,bit dusty in here ;)
« Reply #9 on: 11 June 2013, 14:16:13 »
Any use ??
« Reply #10 on: 11 June 2013, 14:27:32 »
Might need more that one duster for 5 years worth :o
Page created in 0.028 seconds with 20 queries.
