Pages: [1] 2 3  All   Go Down
Author Topic: I can't see the lights  (Read 15204 times)
denisaok
  • East London
« on: 01 April 2008, 23:15:20 »
Are buttons that control the radio on the steering on a face lift supposed to light up and if they are they easy to fix
To ask a question and feel idiotic for a moment is better than not to ask and be idiotic for a life time.
    • 530D M Sport, 330i Coupe
Re: I can't see the lights
« Reply #1 on: 01 April 2008, 23:24:49 »
Yes they are.... if both sides not lighting up I would say it's a wiring issue.
uktigger
  • Blackpool, Lancs
    • 2003 2.2 Omega CD
« Reply #2 on: 02 April 2008, 01:50:14 »
Don't forget though,  they only light up when the radio is ON!
denisaok
  • East London
« Reply #3 on: 02 April 2008, 08:03:26 »
Thanks for the replys i changed the radio to an aftermarket one as soon after i got the car so their must be a pin on the loom that connects to the controls .Dose any one know which one .
« Reply #4 on: 02 April 2008, 08:42:38 »
will need an adapter, if your head unit supports one
denisaok
  • East London
« Reply #5 on: 02 April 2008, 18:37:41 »
I have fitted steering wheel to head unit adapter and it is working fine. Do the steering buttons take power from radio i had a ccr2006 [e] fitted dose anyone have a wiring diagram showing radio & steering wheel controls.
PS i did not connect the blue so as the date stays on could that have any thing to do with it.
« Reply #6 on: 02 April 2008, 20:29:47 »
Thats exactly why, the illumination power comes from the aux out of the radio.
Is the radio reception any good?
denisaok
  • East London
« Reply #7 on: 02 April 2008, 22:26:12 »
thanks for that DTM hope you dont mind me calling you that radio reception is fine. i will connect the blue wire up over the weekend ,is there a anyway that i can get the date to stay on ?
« Reply #8 on: 02 April 2008, 23:19:39 »
To confirm - you've fitted aftermarket stereo, and the date disappears when you turn it on, and you want it to stay there?
denisaok
  • East London
« Reply #9 on: 02 April 2008, 23:47:11 »
No the date dose not disappears when i turn the radio on, what i found was that if i conneted the blue wire the date tuned off when i tuned the radio on. So what i need to know is ,
1] if i re-connet the blue wire iwill the lights on the steering wheel light up
2] how bo i then stop the date from turning off when the radio is on
hope i have explaned it ok :-/
« Reply #10 on: 02 April 2008, 23:51:07 »
Right. To prevent date turning off when stereo switched on (assuming that everything is wired correctly!), you need to have the MID programmed to say now stereo.
This is certainly possible with older type MID, who need to check on newer type, but I guess it would be similar.
denisaok
  • East London
« Reply #11 on: 02 April 2008, 23:55:09 »
thanks for your quick reply think will have a go on saterday  :y
« Reply #12 on: 03 April 2008, 08:31:57 »
Or cut the wire at the back of the MID.....
« Reply #13 on: 03 April 2008, 16:12:47 »
Can we have a go on mine, the radio display on my MID has always been blank, was thinking it would be nice to have the date always there.
philayl
  • Wirral, Merseyide
« Reply #14 on: 03 April 2008, 18:15:06 »
Hi, I too fitted an aftermarket stereo complete with Autoleads steering wheel adaptor, I have lost the lights on the steering wheel controls, is it easy to get the lights working again?
Pages: [1] 2 3  All   Go Up
