Author Topic: switches/lights  (Read 3953 times)
DC
  • Switzerland
switches/lights
« on: 29 April 2008, 21:29:04 »
all my switches right side of hazard switch are not illuminated any more at night. in the beginning some of the switches were lighting up occasionally but stopped in meantime. What’s the reason
Re: switches/lights
« Reply #1 on: 29 April 2008, 23:14:15 »
Bulbs blown ???
See maintenance guides for how to replace.
cockneyboy100
  • watford
  • this aint me, its my cat
Re: switches/lights
« Reply #2 on: 01 May 2008, 19:15:10 »
i have a full set of switches if you need them mate
 :y :y :y :y
a little tip for you all, never buy stockings for a mermaid
DC
  • Switzerland
Re: switches/lights
« Reply #3 on: 03 May 2008, 21:23:12 »
just found out ECO still lights up ocasionally. Cause of that am inclined to think it is some ground wire rather then bulbs.
Re: switches/lights
« Reply #4 on: 03 May 2008, 21:37:03 »
I would suspect bulbs.......at the end of the day they have a pretty predictable life span so you expect them to go within a reasonable period of each other.
DC
  • Switzerland
Re: switches/lights
« Reply #5 on: 03 May 2008, 21:46:22 »
does it mean change of complete switch or only bulb.
Re: switches/lights
« Reply #6 on: 03 May 2008, 22:03:37 »
If you can solder you can fit new bulbs....
DC
  • Switzerland
Re: switches/lights
« Reply #7 on: 03 May 2008, 22:16:24 »
i would say - new switches. who's gonna bother with soldering
MutantCav
  • Gainsborough
Re: switches/lights
« Reply #8 on: 07 May 2008, 11:25:05 »
Just replace the switches mate, second hand ones arent expensive, probably have all you need here and more hassle than its worth to try changing the bulbs...
Re: switches/lights
« Reply #9 on: 07 May 2008, 12:33:56 »
Problem is, if the bulbs are all getting to the age where they fail, second hand switches might not last much longer. I'd get the soldering iron out, personally.
