Author Topic: How to remove radio info on dash panel?  (Read 2189 times)
Strange
  • Denmark
« on: 02 May 2008, 22:27:29 »
Hey.
I'm having a dubble DIN radio in my omega. Therefore I don't need the info from the radio to display in the dash bord. And now, when i switch on my radio, the display shouts off. Does any of you know which wire i need to give power, so the time and date is shown allways, even when i turn on the radio? I've tried it in my old Omega, but now I've forgotten what I did.
Thanks in advance... :)
Dazzler
  • Haverhill, Suffolk
Re: How to remove radio info on dash panel?
« Reply #1 on: 03 May 2008, 10:04:10 »
On the old Omega you just cut the red/white wire IIRC :-/
« Reply #2 on: 03 May 2008, 10:07:38 »
its the 12v feed/signal from headunit to MID.  Same signal used to signal aerial amp and power amp, so cut it mid end
Albert1
  • Herts
« Reply #3 on: 07 May 2008, 16:57:47 »
Always grab the cat first, before you cut the wire - in case it's the wrong one and you have to make a run for it....
Dazzler
« Reply #4 on: 07 May 2008, 17:09:44 »
Thats red and white not red or white ;)
