speakers on the way out
Started by Gaffers, 26 May 2008, 18:01:16
Gaffers
I have an original radio setup in my car but the speakers are on the way out, you know that slight crackly noise.... how did that happen?  ::) ::) ::)
I am wondering what is the most cost effective way of solving the problem, note I live in Germany where there are no breakers?  :(
Many thanks in advance  :y
Martin_1962
QuoteI have an original radio setup in my car but the speakers are on the way out, you know that slight crackly noise.... how did that happen?  ::) ::) ::)
No breakers - why not?
Dave DND
When you crank up the speakers to full volume, the voice coils inside the speakers get hot. The voice coils are the copper windings of cable that form the main part of the speaker`s drive mechanism. As teh coils get very hot (a heating element is nothing more than a coil of wire also) the resin that binds them together starts to melt and deform. As this deforms it then rubs against the inside of the magnet and eventually wears through and short circuits the coil, eventually resulting in the burning out of the speaker, but the tell tale signs are the crackles as it moves in and out. If you do not change them now, the speakers will burn out and could damage the head unit or amplifier that is driving them.
QuoteNo breakers - why not?
Due to the very stringent motoring laws, aftermarket and pattern spares are also in restricted / short supply - I would imagine secondhand stuff to be almost impossible to obtain. Worth going over the border to a neighbouring country though . . . . . !!
Radio & Decoding Technician
www.dndservices.co.uk
I personally would see it as an opportunity to replace them with some better speakers than the standard ones, with better power handing, for a start. Why go to all the hassle of removing door cards, etc. only to replace like with like?
Dave DND
QuoteI personally would see it as an opportunity to replace them with some better speakers than the standard ones, with better power handing, for a start. Why go to all the hassle of removing door cards, etc. only to replace like with like?
I really couldn`t agree more !!
Gaffers
I know the square root of break all about speakers..... what do you recommend that wont break the bank and give good bass  :y
Whilst they certainly can be improved upon, esp at volume, std fit ain't all that bad, with most of the distortion coming from HU amps...
Martin_1962
QuoteI know the square root of break all about speakers..... what do you recommend that wont break the bank and give good bass  :y
Infinity 6.5 components or equivalent
Used to be 605CS now 6520 I think
Components, but you may have problems locating the crossovers, also love amplifiers
Facelifts - they go in the arm rests
Martin_1962
Or Kappa 65.7CS
I am confused, changed a bit on hte models since I bought mine - I paid just over £90
I'm guessing the HU has already been upgraded as the standard one wouldn't be capable of frying the speakers. Just guessing though. :-/
Be aware that some decent speakers are less sensitive so need more power to achieve the same volume levels. Not an issue if you have an amp or a head unit with decent output, but might be worth thinking about if you're retaining the factory head unit.
You could either fit a pair of woofers and keep the factory tweeters or change for a decent set of 2 way speakers, although you'll have to find somewhere to hide the crossover as Martin said.
Also, the limiting factor in bass response is the limited volume within the door that the speakers have to work against. Aftermarket speakers will improve on the factory ones in this respect IME but don't expect miracles.
Best way is probably to go to a car audio shop and see what's available  for your budget and what they recommend.
Pete Elite
http://cgi.ebay.co.uk/Vauxhall-Omega-Infinity-Speakers_W0QQitemZ330239351742QQihZ014QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  You could try these if they will post, no harm in asking and you'll know they fit ok.
  Hope this helps,
                        Pete :y.
Martin_1962
No cross overs or tweeters for the components
Gaffers
QuoteNo cross overs or tweeters for the components
Cant I use the tweeter that are already there?
And what are the crossovers?  :-?
MikeDundee
I have a set of four speakers front and rear, removed from the facelift almost 3 years ago, there around somewhere upstairs ::)
Martin_1962
Could do
Crossovers stop the high frequencies going to the woofer, and low frequencies to the tweeter
