EGR valve bypass
Started by perfferle, 30 May 2008, 19:59:02
perfferle
Hi, Is there a proper method to bypass (electrically) the EGR valve on the 2.5L 1999 V6?
Dazzler
Not sure why? :-/
We normally blank it mechanically and leave the electrics connected.
markey mark
no mate all you can do is blank it off ::)
perfferle
Ok, just wondered if the fuel mixture / something else was affected when the valve operated. The valve appears to be the cause of an intermittant rough idle RPM condition that i experience when the engine is up to temperature.
Thanks :y.
markey mark
blank it off matey !! :y
perfferle
