Author Topic: CCr700 tele mute  (Read 6519 times)
Dazzler
  • Haverhill, Suffolk
CCr700 tele mute
« on: 16 June 2008, 14:18:19 »
Does the CCR700 have a telephone mute wire that i can attach a bluetooth kit too?????
Re: CCr700 tele mute
« Reply #1 on: 16 June 2008, 14:21:58 »
Yup.  Has mute line, and aux in so you can feed audio from phone to car speakers
Dazzler
« Reply #2 on: 16 June 2008, 14:42:14 »
I cant find anything in the book, so could you tell me the wires please and what i need to do the input?
Thanks muchly
« Reply #3 on: 16 June 2008, 14:51:28 »
Thanks muchly
If your car is prewired, use the relevent autolead, much easier. That how I've done mine.  If you don't have the plug above glovebox, then you'll have to do manually - look for a diagram on net, as the method of counting the pins seems to vary, but you're looking for the Mute line and the 2 aux in (audio in + and audio in -) which connect to the speaker output of phone kit
Dazzler
« Reply #4 on: 16 June 2008, 14:57:28 »
So im looking for a plug above the glove box then??
I take it i need to remove the glovebox to do this??
What colour is the plug and how many wires going into it??
Cheers Jaime
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #5 on: 16 June 2008, 16:24:18 »
Daz the plug is taped to the metal bar that runs across the bulk head behind the glove box and needs the box to be removed. it is normally held up with some white tape and the plug colour is black. :y
Jaguar XJ6
Dazzler
« Reply #6 on: 16 June 2008, 18:05:49 »
Thanks Gary, will have to find a how to, to remove the glovebox.
What is the Autolead called then , any ideas??
miggy
« Reply #7 on: 16 June 2008, 19:25:28 »
Have a look here, i got mine from here last week
http://www.siocommunications.co.uk/Shopping/logout.php
Dazzler
« Reply #8 on: 16 June 2008, 19:28:11 »
Would you have a p/n by chance please, as you need to register just to look around the site >:(
miggy
« Reply #9 on: 16 June 2008, 19:35:24 »
Look on the left of the page, select telemute leads then go from there, i used it without a log in and i also used the shop.
miggy
« Reply #10 on: 16 June 2008, 19:38:49 »
Try this
Go to the autoleads tab and you can look at all the telemute leads for all cars
« Last Edit: 16 June 2008, 19:41:10 by miggy »
« Reply #11 on: 16 June 2008, 19:47:55 »
Or try Dave DND.... ;)
Dazzler
« Reply #12 on: 16 June 2008, 19:56:52 »
http://www.siocommunications.co.uk/06-053B.html
I found this one, but it looks like it connects behind the radio as its a standard mass ISO block connector....
Am i missing something here :-/ :-[
« Reply #13 on: 16 June 2008, 20:07:15 »
Do you have the plug above glovebox?
Dazzler
« Reply #14 on: 16 June 2008, 20:13:24 »
Have not removed glove box yet, will do that tomorrow, if i can work out how to do it...lol
