Author Topic: Climate control - slight issue with dual zone  (Read 7288 times)
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« on: 16 April 2008, 00:35:23 »
When I got the car, before the RAC touched it...
When I set the temp on the drivers side it would adjust the passenger side too, now it doesn't there both independant of eash other.
Any idea's ?
JonR
  • Gloucestershire
Re: Climate control - slight issue with dual zone
« Reply #1 on: 16 April 2008, 12:53:07 »
Same here, Does it sometimes tho
 HELP?
minimeee
« Reply #2 on: 16 April 2008, 12:57:18 »
Dunno bout pre-facelifts but my facelift is always independant from the passenger, is that not how its supposed to be???
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #3 on: 16 April 2008, 13:07:52 »
when I first got the car if you changed the drivers side the passengers side changed as well unless the passnerger changed theres then it went individual, untill the ign was turned off and back on.
Maybe its a diffrent set up on the newer ones,
minimeee
« Reply #4 on: 16 April 2008, 13:10:30 »
yeah it sounds that way cos my drivers knob has neva changed both, would make sense though cos its a pain in the ass changing both all the time when on my tod
« Reply #5 on: 16 April 2008, 13:28:40 »
If you push in either of the knobs on the facelift climate control the single knob takes over control of both sides. Push it again and they separate. When a single knob is active the temperature display above the other one is blanked.
Not sure about prefacelift but I would imagine there's some similar mechanism.
minimeee
« Reply #6 on: 16 April 2008, 14:01:52 »
and there's me thinking that just switched 1 side off, i've had the motor over a year now as well, cheers bud  :y
« Reply #7 on: 16 April 2008, 17:22:19 »
On the pre face lift cars the passenger's side follows the driver's side untill you press the passenger's side & then they're seperate. They become as one again after the ignition has been off for ...... er? an hour? .... can't remember. :-?
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #8 on: 16 April 2008, 17:29:56 »
Thats what I thought, but I can leave it stood for a couple of days... oh well no biggy
Danny
  • Wigan, Greater Manchester
« Reply #9 on: 16 April 2008, 18:16:57 »
when turning the passenger side on using the driver side knob, the passenger side should come on at the same temp as the drivers and be completely independantly adjustable via its own knob, ie when both are on and you change the driver temp, the passenger will remain at whatever temp it was left on. if you turn the driver temp up, then switch the passenger side off and back on via the driver side knob, it'll come back on the same temp as the driver side
pretty certain this is the norm, its been like this in my current facelift elite and my previous facelift GLS
« Reply #10 on: 16 April 2008, 19:16:26 »
Correct. 40mins is the timeout with ign off iirc.
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #11 on: 16 April 2008, 19:18:15 »
Any idea's why mine wont time out ?
« Reply #12 on: 16 April 2008, 19:48:25 »
Botched wiring (ie, its always got ign on signal)?  Stuck buttons?
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #13 on: 16 April 2008, 19:53:51 »
Botched... maybe after the other trouble...
No buttons stuck, and it turns off after about 8 seconds after the igntion is turned off
« Reply #14 on: 16 April 2008, 19:58:58 »
can only think panel then :(
