Author Topic: Laser Failures and CDRs  (Read 8858 times)
« on: 21 June 2008, 09:44:02 »
Also, do I remember reading on here that the CDR500 doesnt really like CDRs??
Correct - never designed to be compatable  :y
And now for the deluge that will now post saying that their unit may play them   >:(
I have noticed that Philips players in particular seem to be more prone to tired lasers after a lifetime of cdrs.  Is that your experience?
I have a Carin unit here that spits out all disks, and when I acquired it it had CDR in it.  Mrs TheBoys changer in the Rover (R770 HU, I think 036 changer) is Philips, and seems to be troublesome now :( (though it is 10yrs old, so can't grumble)
The changers in my Omegas (CDC2) seem to fair much better, but don't like cheap media, so Verbatim only.  My old 10 disc Kenwood from circa 1992 is still going strong, and has been used with CDRs since I got a writer mid nineties when they first came out (at 'sensible' prices (ie in the £100s)).
Is it a case that whoever supplies the lasers for the mechs used in early Kenwoods and the CDC2 are more suited than the Philips (who presumably use their own?) lasers for CDRs, and are able to focus on it better?
Or is my experience uncommon?
« Last Edit: 21 June 2008, 11:59:46 by TheBoy »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
CDRs and Laser Failure
« Reply #1 on: 21 June 2008, 11:11:47 »
TB
There is indeed a definate difference between makes and models as you righly point out. Philips often use thier own lasers, whilst Kenwood and Blaupunkt tend to generally favour the Sony lasers.
Looking over the past years between units that have played original discs only, and units that play CD`rs, the lifespan would appear to be
Original Discs use only:
Philips lasers approx 8-10 year lifespan - Sony lasers around 10-15 years.
Using CD`rs on a Non CDR designed player:
Philips lasers under 2 years - Sony lasers around 4 years.
Using CDR`s on a player Specifically designed to play CDR:
Not enough failures yet to spot any definative patterns.  (approx 5 years monitoring so far)
Generally speaking:
Aftermarket CD players introduced the ability to play CDR around 2001
Units before this date are NOT generally CD/RW compatable
OEM CD players introduced the ability to play CDR around 2005
OEM Navigation systems tend to bend the rules a little, as the data used is often in a more compressed format and the lasers are of a higher spec. These can often read CD`rs although the occasional duff read when first powered up from cold is usually more to do with condensation on / within the disc (they are not sealed at the edges like real discs) and not often suffer from laser failure.
Please note that these results are based purely on around 10,000+ cd players that we have seen over the last 15 years or so and are not part of any investigative experiment. Purely from data collated at time of repair submission or completed repair.
Certainly some patterns there to spark off some topic of conversation I think !!
« Last Edit: 21 June 2008, 11:59:27 by TheBoy »
Radio & Decoding Technician
www.dndservices.co.uk
Re: CDRs and Laser Failure
« Reply #2 on: 21 June 2008, 11:28:10 »
Firstly, want this to be a meaningful discussion, rather than a 'it works for me' slanging match, so can everyone bear that in mind before posting.  Dave DND has posted his extensive experience above :y
« Reply #3 on: 21 June 2008, 11:31:42 »
Dave DND - my own experience suggests I get longer out of my Changers than average would suggest.
The (now dying) Philips changer in the Rover as probably only ever seen 1 or 2 pressed CDs, and is now 10yrs old.  The (still going strong) CDC2 in my MV6 has only had CDRs in the 4.5yrs I've had it (just replaced for another CDC2, but due to changing to crt700 HU).
Am I lucky, or is it that I only use premium disks (Verbatim) a factor?  It seems I have had the expected life out of the Rover's Philips changer, even though purely using CDRs instead of pressed disks  :-/
I should add, none of my cd changers will play CDRWs, so we're talking purely CDR here
« Last Edit: 21 June 2008, 11:33:27 by TheBoy »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 21 June 2008, 11:50:05 »
Remember that my findings will also rely heavily on "average" car mileage and vehicle usage. If you use a car every day, all day, then your unit may wear out faster than if only used for Sunday best. I never thought to add mileage to vehicles when booking cars in all those years ago.
A number of people have commented on the use of Good brands, but that does not mean that the format of the media has altered. The lasers are struggling to see computer recorded data that is a lot smaller that audio data. Some comments have previously been made about the new Sony Audio recordable discs, but as yet my findings are inconclusive at this early stage.
I haven`t differentiated between the formats here. My findings are based on either shop bought pre-recorded discs, or self recorded discs, whether they be CDR / CDRW / CDV / VCD or anything else meant for your home computer.
« Reply #5 on: 21 June 2008, 12:02:37 »
My cars, as an average, have their CD players on for 1-2hrs, 7 days a week...   ...obviously long runs will be more, but some days we don't use the cars...
JueV6
  • Kent
Re: Laser Failures and CDRs
« Reply #6 on: 21 June 2008, 16:08:33 »
Dave / TB
I have a carin unit in my elite and as TB say, it spits all disks out. (no Disk in it when i got the car). I've taken teh cover off and watched as a cd loads and the disk won't / doesn't spin. It then spits the disk.
Although that doesn't seem to be a laser issue, have either of you any idea's
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 21 June 2008, 16:26:35 »
That can often be a sign that the laser is too weak to see the disc, or that either the disc or the lens is dirty and needs cleaning.
Try a different disc, audio or computer and see if the disc "spins" briefly before being spat out - if it does, then sounds like a laser failure.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #8 on: 21 June 2008, 16:58:36 »
my mrs rover cdc didnt work when we bought it its a 97 R reg 414 Si so i ripped it out and put in my old chavmaster Alpine hu w disc changer this has only ever had CDRs in and is now around 6 years old no problems with it yet! :y
mv6 tho  >:(
my mv6s CCRT changer i think is jafferd everytime i go over a bump it stops working makes funny speaker noises and decides theres an error with the cd even with pressed cds
however itll play  whats ever in slot 5 perfectly ok
any ideas dave? looks filthy and dusty inside and its been prone to damp as the casing is alittle rusted come out of a scrap elite
« Last Edit: 21 June 2008, 16:59:55 by tmx »
« Reply #9 on: 21 June 2008, 17:26:21 »
mv6 tho  >:(
Sounds like a dust/dirt issue there, especialy when it plays disk 5 ok, have you checked the caddy for damage?
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #10 on: 21 June 2008, 18:08:17 »
yep checked caddy ill get a CD cleaner disc
« Reply #11 on: 21 June 2008, 19:51:35 »
What is the failure mode, normally? Laser diode itself kaputt or the focus coils?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 21 June 2008, 19:59:56 »
Sounds like a dust / dirt sissue to me as well, although I would tend to remove the covers and clean the lens manually - gently with a cotton bud - NO CHEMICALS !!
Mixture of both really, but the focus coils tend to be a sign that the laser power will give up shortly afterwards. Not that it really matters, the focus coild cannot be changed independantly on most of the In Car Stuff - laser module failure is Laser module failure !!
« Reply #13 on: 22 June 2008, 10:31:08 »
And chances of getting a new laser for my philips changer thats on its way out (036 is changer model)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #14 on: 22 June 2008, 10:45:17 »
Quite a few of the Philips lasers are still available, although obviously not from Philips!
Pattern ones are readily available also -
What part number are you trying to find? (written on label of laser)
