NCDC series - CDC SAFE
Started by TheBoy, 14 July 2008, 13:22:36
QuoteTunnies is the one with CDC problem.  Paired to display, but not 'depairable'  :'(
Could be to do with the CD issue possibly.
Wont allow a de-pair until all units are happy?
I think the carpass we have does not match the radio/CID
Did he not have two sets?
Depends on your definition of 2 complete sets!  Someone has had a real go at both of them.
If we can get him 1 complete working set out of the 2 sets we have (looks complete, excpet missing 1 cdc board), we can have the 'leftovers' for ourselves ;)
Have you tried the CDC board out of the 2015?
Not yet, seeing as 2015 is 'yours'
Well give it a try.... :y
Okey dokey.
Seeing as I'll need to do it on my testbed, the wiring for rgb is easily found in a well known piece of software (btw, you should have email regarding that)?
Actually, IIRC, RGB cable only used for satnav function anyway, so could just use the signal can connection?
QuoteOkey dokey.
Correct.....without the RGB you simply dont get map functions, all the rest works and the satnav defaults to histograms.
