Xenon
Started by miggy, 23 May 2008, 19:43:23
miggy
I am looking at maybe fitting a set of Xenon headlights on the GLS Omega, is it a case of just getting the headlamps or do i need other equipment, there is a set for sale and they come with the looms and connection but it does not mention anything else, surley other items would be needed.
QuoteI am looking at maybe fitting a set of Xenon headlights on the GLS Omega, is it a case of just getting the headlamps or do i need other equipment, there is a set for sale and they come with the looms and connection but it does not mention anything else, surley other items would be needed.
To do properly (and legally), you need an automatic levelling system and a headlight washing system.
JezInBrum
More practicle to fit an aftermarket kit, less messing overall.
I found this company using a google search.
http://www.hids4u.co.uk/store/home.php There others out there so shop about
QuoteMore practicle to fit an aftermarket kit, less messing overall.
Be aware aftermarket kits are not legal to use on UK roads....
mkaminski100
And you might have a problem on MOT.
JezInBrum
Sorry to drag this subject up again. I just had a lightbulb moment. Regarding the legality, I am sure I saw That Edd China bloke fit an after markey set onto a Lexus on that bring a wreck back to life & flog it for a fortune show fronted my Mike Brewer. Or have they put in legislation since that would have been made?
JueV6
I believe xenons are ok but HIDs are still illegal Jezz :y
Read the post we have in the FAQ section regarding HID's
To put it in a nut shell, there is no specific legislation which makes it illegal to fit a HID conversion as long as the bulbs are marked with the correct regulatory approvals.
There are specific rules that cover the fiting of HID's in new cars for type approval.
And no, as long as the beam pattern is correct, they will not fail an MOT as there is not specific criteria to check this either.
Please also remember WHY the headlamp washers are fitted ....  and I don't just mean for legal reasons ... :(
HID lights are DIFFERENT .. and they are badly affected by even small amounts of crap on the lenses, far more than normal halogen lights are.
The deterioration in "cast" light is subtle and can easily not be noticed until it is really poor.
I'd hate to think someone had a serious accident simply 'cos they fitted HID's to "look good" and were driving with restricted vision due to simply dirty lenses.
Just my opinion .. thats all   ;) ;)
QuotePlease also remember WHY the headlamp washers are fitted ....  and I don't just mean for legal reasons ... :(
I disagree....HID light is exactly that....light i.e. photons its just generated using a discharge method rather than a incandescent filament.
Its not affected differently at all because photons are photons!
The only thing you might be able to state is that because there is 3 times the light output that any dirt will drop the light by a set percentage so the light drop off will be more noticeable but, you have to loose a lot to get down to the levels of a standard halogen lamp!
The importnat thing is maintaining the correct adjustment for the headlight but, this is trus of those with auto leveling anyway :y
AFAIK HID light is from a much narrower spectrum (wavelength), and so is far more prone to "scatter" than halogen light which is from a broader spectrum. As HID lights are more "directed" by the HID lens rather than the headlamp "glass", dirt on the "glass" causes far greater "scatter" and loss of illumination on the road.
Now I'm no expert on this in any way, I'm only repeating what I was told some years back - it's probably all rubbish .. but does make some sense to me   :-/ :-/ :-/ and is, supposedly, the reason the "Construction and Use" regs insist on washers for HID lights.  :question :question
HID light is actually a wider spectrum of light than incandescent.
And both the Halogen and HID use ball lense type focus setups.
So yes, its all rubbish  :y
Dirt does not tend to cause scatter nearly as much as water does (no surprise) it generally just attenuates the output.
tmx
our local plod have cracked down on these HID kits they are fining all the boy racers £80 and making them have one of them defect notices!
and so they should! you can spot hid kits miles away as they are to bright and dont level properly so blind everyone! causing accidents
also HID lights use some serious current and judging by the guage of cable on my mv6s they could potentially kill
Quoteour local plod have cracked down on these HID kits they are fining all the boy racers £80 and making them have one of them defect notices!
If they are bulbs with the correct approvals then what they are doing wont stand up in court.........
They also use less power (about 35W) but are high voltage so the cable you can see is all insulation with small conductors :y
tmx
they have this operation called BLACKOUT or summat was in the paper they only just got ANPR  [smiley=rolleyes.gif]
but yep theyre doing it like there doing boy racers for excessive noise they had a write up on it in the local rag about non standard hids cause accidents and dazzle motorists
