Radio Code
Started by DaveBrunel, 19 July 2008, 18:28:13
DaveBrunel
Hi people, 1st post, scuse if I ramble.
After battery went flat, display said SAFE, no radio. Recently had a new power sounder from Vauxhall, they had to order me a new CAR PASS for codes to do the work, cos when I bought it the seller had no codes, and no user manual. The car pass has a radio code, key code, immob code etc etc. After some guesswork I held AS button and powered up radio, got 10---- and entered code from the new Vauxhall car pass. I failed to press AS again to set, so tried again, pressing AS after code but still no good, now I'm down to 7 SAFE, and it will not come up with 7----, no matter how long I hold AS button. Should I stop messing or persevere? Is there a chance that the radio code on the car pass is wrong? And if I disconnect/reconnect the battery will I then get 7---- ? HELP.     very annoyed. >:(
VX1
Sounds like the prevoius owner had another radio fitted in (vauxhall radio) and has lost the code for it or has a second hand one fitted. The best thing to do is contact dave he is the radio man on the forum and he can get the code for you (at a cost). I think its DaveC is his username, I am sure someone will be a long to clarify this for you.
Paul  :y
Vx Trade club card holder
Halfords trade card holder
HolyCount
@Tis DaveDND :y :y
Helped me out with mine (at a cost) -- great guy
tmx
speak to forum user: Dave DND hes our ICE expert and can decode some vx radios online i think his web addy is http://www.instant-radio-codes.com/
Dave DND
If you have got down to 7 SAFE then you have entered a wrong code 3 times. Because the code you have is incorrect, you will need to leave the radio switched on and powered up, with the ignition on for two hours as a penalty for using a wrong number.
When it resets, do not enter the same number again, as it is obviously wrong, and each wrong attempt will result in a longer wait between goes.
Yes, it would appear as if the car pass is for another radio, but unable to advise further without knowing which radio you have fitted.
Radio & Decoding Technician
www.dndservices.co.uk
DaveBrunel
Thanks Dave - it's a CCR 2006.
Just a thought - when Vx had the car recently to fit the new alarm power sounder, would they have had to disconnect the battery?
If they did, they must have got a radio code somehow, cos the radio has been fine till I let the battery go flat 2 days ago. Then if so maybe I DO have the correct code, but I've done it wrong on three attempts, maybe by not holding AS button in long enough. I know I put the correct digits in, but it did not beep. :-/
Dave DND
QuoteThanks Dave - it's a CCR 2006.
Although many service books suggest to disconnect the battery first, it is unlikely that the garage would have done this, I know that we would not have !
If you are entering the number and the counter is going down, then you have the wrong code number, its as simple as that.
I can decode that model if you get stuck, please follow this link
http://ice.dndservices.co.uk/shop_show_item.php/MID/39/ISS/40/IID/127/PAGE/shop_decode_index.php
DaveBrunel
OK Thanks Dave, I order up a decode and send it off to you.
Cheers
Dave
